Ip services - reverse proxy
Hello. I have updated from 7.21.5 to the latest long-term and I found the ip services reverse proxy enabled...
I didnt have any service on 443, just the www on port 80 (protected by a specific ACL on the input part of the firewall).
Question: is it possibile that Mikrotik enables by default one IP SERVICE that exposes the daemon on the 443/tcp ? I think I need to go on every device and disable it!
I did some port scans, and it looks like nothing is listening on that port if you have not added anything to /ip reverse-proxy yet. So it's not that critical that reverse-proxy is enabled by default under /ip service.
But I still disabled that on my devices because I've no need for the feature.
doing upgrade to beta 25.3, i checked ip services ports and it was enabled again, even if i was sure it was disabled before upgrade....
reverse-proxy can not listen 80 443 at the same time , usually we need do with http 80 request return 301 to https ,Unfortunately, without simultaneous monitoring of HTTP and HTTPS, I would not be able to use it
