Hi.
Can somebody help.
I have mik Rb951-ui setup as router, standard wifi configuration, when my customer thray to connect Sonos and Iphone together, from some reason refuse to connect together.
When customer through app in one moment connecting Sonos, I see Sonos on network, but from some reason app on Iphone don’t want to do final step. It stuck on final step and don’t want to connect with Sonos.
Please can somebody help.
Thanks in advance
It would help if you share your configuration (using code tags, the brackets button):
/export hide-sensitive file=anynameyoulike
What You want to export, all configuration or only wifi?
All of the config, many items have interdependencies and only showing bits and pieces is not usually fruitful.
OK
Here is my config
apr/03/2021 16:05:59 by RouterOS 6.45.4
software id = QZGY-0KM9
model = 951Ui-2HnD
serial number = B8570B0E83A0
add admin-mac=C4:AD:34:43:6D:21 auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode
band=2ghz-g/n disabled=no distance=indoors mode=ap-bridge ssid=
"PALMA II-10" wireless-protocol=802.11 wmm-support=enabled
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=""
mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp_pool0 ranges=192.168.10.2-192.168.10.100
add address-pool=dhcp_pool0 disabled=no interface=bridgeLocal lease-time=
1w10m name=dhcp1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
add bridge=bridgeLocal interface=wlan1
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal interfaces=wlan1
add address=192.168.10.1/24 interface=bridgeLocal network=192.168.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
ether1
add address=192.168.10.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.10.1
netmask=24
set allow-remote-requests=yes
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name="MikroTik-Stan 10"
/system leds
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
set 4 disabled=yes
set 5 disabled=yes
/tool romon
set enabled=yes
Please do at least the following:
- Upgrade to latest LTS (6.47.9): https://download.mikrotik.com/routeros/6.47.9/routeros-mipsbe-6.47.9.npk
- Don’t ever use WPA-PSK, only use WPA2 AES (wpa2-psk)
- Choose a channel (either 1, 6 or 11) and bandwidth 20MHz
Well, I change the wifi configuration only because I try to see if ipone and Sonos will connect. I all ready have configure channel 6 and 20Mhz
Only what is left is upgrade. Personaly I don't think this will help.
Funny as there is no channel configured according to your export.
In regards to the RouterOS version…it is old and should not be used from security perspective.
Did you miss the WPA security setting remark?
Yes, I see the export config, maybee is problem because this Rb951-ui whose setup as CAP, I try to configure in Capsman client to client forwarding, but no luck, then I remove from Capsman and configure as router, but I configure channel and bendwidth.
How is possible that export not show those configuration.?
Thanks in advance
Update the firmware and to get your network going, dont use capsman (at least for now), and it only adds complexity to a config and more work for the router and IMHO not worth it unless one has many access points. Talk less update more! ![]()
I have Sonos on one of my networks and Iphones links perfectly without problem, just make sure they on the same network, check DHCP that it release IP address to Sonos and that it must be the same subnet as your users who want to use it.
Also if running hotspot put Sonos in IP-Binding.
Other location I cannot link cause everyone is on different VLANs (Children & Parents) different firewall rules. So just the parents’ subnet can play Sonos the kids not.
