IPsec between two internet MT hosts!? how?
I have two MT routers in different locations, with different network on them. The mission is to make an VPN secure tunnel between this two hosts.
SOLUTION: to encrypt via IPsec all packets from/to this two MT hosts, and after this to configure an L2TP VPN tunnel, and config routes.
PROBLEM: I cant configure IPsec so that encryption between host A-81.12.224.37 and B-194.145.145.254 have been made. This are public IPs for MT routers, on this IPs will run L2TP VPN tunnel, this are the IP from/to I want to encrypt all the traffic.
Please help to understand how to do it…
Or even am I right with this config…?
thx
http://www.mikrotik.com/docs/ros/2.9/ip/ipsec
I read this manual many times. I need answer to this question. I think that maybe its not the right network scheme that i wrote. please sombody explain a little.
Make sure you have the newest versions of RouterOS - I’ve had problems with differing 2.9x versions, while same configuration on newer versions worked flawlessly.
Hard to tell as you haven’t posted the config.
Also, the IPSEC log from each router.
Regard
Andrew
