IPsec ikev2 between CHR on AWS and local mikrotik
Hallo,
I’m trying to establish a site to site Tunnel between my Chr on aws and a local mikrotik with private IP.
IPsec ikev2 between CHR on AWS and local mikrotik with private IP (behind NAT)
Wil this be possible? Any leads will be highly appreciated.
Yes, it’s possible. There are plenty of leads and step-by-step guides if you google: “AWS Mikrotik IPsec
Thank you for the link, I will try and configure it with the guide and see what works…I’ll get back shortly.
I have tested all of these guides and none worked. It’s either my configs are the issue or none of the guides is addressing my exact issue.
My CHR is hosted on AWS and my local mikrotik WAN is a private IP address issued by my ISP.
If possible I would appreciate a step by step guide of both Routers configs.
