I have model RB760iGS (Hex S).
Trying to set up vpn to privateinternetaccess peer via ipsec mode-config.
Configuration
/ip ipsec:
/ip ipsec mode-config
add connection-mark=via-vpn-pia-uk name=pia-uk responder=no
/ip ipsec policy group
add name=pia
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha512 name=pia
/ip ipsec peer
add address=uk-london.privateinternetaccess.com exchange-mode=ike2 name=pia-uk profile=pia
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=pia pfs-group=modp2048
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=pia-uk notrack-chain=prerouting password=\
verystrongpassword peer=pia-uk policy-template-group=pia remote-id=fqdn:*.privateinternetaccess.com username=x0000000
/ip ipsec policy
add dst-address=0.0.0.0/0 group=pia proposal=pia src-address=0.0.0.0/0 template=yes
/ip firewall:
/ip firewall address-list
add address=10.0.10.0/24 list=nat-internet
add address=10.0.30.0/24 list=nat-internet
add address=10.0.50.0/24 list=nat-internet
add address=10.0.110.0/24 list=nat-internet
add address=192.168.130.0/24 list=nat-internet
add address=10.0.0.0/8 list="Private Networks RFC 1918"
add address=192.168.0.0/16 list="Private Networks RFC 1918"
add address=172.16.0.0/12 list="Private Networks RFC 1918"
add address=127.0.0.0/8 list="Loopback adresses"
add action=drop chain=input in-interface-list=wan src-address-list="Local Networks RFC 4193"
add action=drop chain=input in-interface-list=wan src-address-list="Private Networks RFC 1918"
add action=accept chain=input in-interface-list=lan protocol=icmp
add action=accept chain=input connection-state=new dst-port=80,8291,22 protocol=tcp src-address=10.0.2.0/24
add action=accept chain=input dst-port=163 protocol=udp src-address=10.0.2.1
add action=accept chain=input connection-state=new dst-port=53,123 in-interface-list=lan protocol=udp
add action=accept chain=input comment="accept established, related, untracked" connection-state=established,related,untracked
add action=accept chain=output connection-state=!invalid
add action=accept chain=forward in-interface-list=lan-trusted out-interface-list=lan-trusted
add action=accept chain=forward connection-state=established,new in-interface-list=lan out-interface-list=wan
add action=accept chain=forward connection-state=established,related in-interface-list=wan out-interface-list=lan
add action=drop chain=forward comment="drop ALL from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-inter
add action=drop chain=input log-prefix=drop-input
add action=drop chain=output log-prefix=drop-output
add action=drop chain=forward log-prefix=drop-forward
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=blackhole passthrough=yes src-address=10.0.31.0/24
add action=mark-connection chain=prerouting new-connection-mark=via-vpn-pia-uk passthrough=yes src-address=10.0.31.0/24
add action=masquerade chain=srcnat out-interface=ether1-wan src-address-list=nat-internet
_Some type of kill-swich feature based on topic http://forum.mikrotik.com/t/blackhole-unreachable-with-ipsec-policies/131549/1
add name=bridge2-blackhole
add distance=1 gateway=bridge2-blackhole routing-mark=blackhole
ip firewall nat and mangle after successful connection to peer
/ip firewall raw print
0 D ;;; ipsec policy
chain=prerouting action=notrack src-address=0.0.0.0/0 dst-address=10.0.3.105
1 D ;;; ipsec policy
chain=prerouting action=notrack src-address=10.0.3.105 dst-address=0.0.0.0/0
/ip firewall nat print
0 D ;;; ipsec mode-config
chain=srcnat action=src-nat to-addresses=10.0.3.105 connection-mark=via-vpn-pia-uk
1 chain=srcnat action=masquerade src-address-list=nat-internet out-interface=ether1-wan
And it does not work - I can not get access to the Internet via 10.0.31.0/24.
Need some expertise and explanation why it does not work.
Advice what should I do will be very handy too.
