i got the exact same problem when i try to connect my iphone6 via L2TP/IPsec over 3G … no luck…
PPTP works immediately over 3G
when my iph6 is connected to a WiFi then both works L2TP/IPsec and PPTP
i accept input for Protocol 51 (ipsec-ah) and Protocol 50 (ipsec-esp) and have opened the ports 500, 4500, 1701 for L2TP/IPsec and 1723 for PPTP VPN.
LOG output below and here are the firewall settings for the VPN connections:
[spippan@RB951_sp-private] /ip firewall filter> print
0 ;;; accept WHITELIST ACL input
chain=input action=accept src-address-list=whitelist log=no log-prefix=""
1 ;;; accept WHITELIST ACL forward
chain=forward action=accept src-address-list=whitelist log=no log-prefix=""
2 ;;; ADMIN Blocked via ACL "admin_block"
chain=input action=drop src-address-list=admin_block log=yes log-prefix=""
3 ;;; ADMIN Blocked via ACL "admin_block"
chain=forward action=drop src-address-list=admin_block log=yes log-prefix=""
4 chain=input action=accept protocol=ipsec-ah src-address-list=!VPN_blacklist log=no log-prefix=""
5 chain=input action=accept protocol=ipsec-esp src-address-list=!VPN_blacklist log=no log-prefix=""
6 ;;; allow VPN from OFFICE HP
chain=input action=accept protocol=udp src-address=62.218.xx.xx dst-port=1701 log=no log-prefix=""
7 ;;; allow VPN from OFFICE HP
chain=input action=accept protocol=udp src-address=81.189.xx.xx dst-port=1701 log=no log-prefix=""
8 ;;; drop BLACKLISTED L2TP VPN connectors
chain=input action=drop protocol=udp src-address-list=VPN_blacklist dst-port=1701 log=no log-prefix=""
9 chain=input action=add-src-to-address-list connection-state=new protocol=udp src-address-list=VPN_stage4 address-list=VPN_blacklist address-list-timeout=2w dst-port=1701
log=yes log-prefix="vpn_blacklisting>"
10 chain=input action=add-src-to-address-list connection-state=new protocol=udp src-address-list=VPN_stage3 address-list=VPN_stage4 address-list-timeout=1m dst-port=1701 log=no
log-prefix=""
11 chain=input action=add-src-to-address-list connection-state=new protocol=udp src-address-list=VPN_stage2 address-list=VPN_stage3 address-list-timeout=1m dst-port=1701 log=no
log-prefix=""
12 chain=input action=add-src-to-address-list connection-state=new protocol=udp src-address-list=VPN_stage1 address-list=VPN_stage2 address-list-timeout=1m dst-port=1701 log=no
log-prefix=""
13 chain=input action=add-src-to-address-list connection-state=new protocol=udp address-list=VPN_stage1 address-list-timeout=1m dst-port=1701 log=no log-prefix=""
14 ;;; ***allow L2TP ports
chain=input action=accept connection-state=new protocol=udp dst-port=500,4500,1701 log=yes log-prefix="L2TP>>>"
15 ;;; drop BLACKLISTED PPTP VPN connectors
chain=input action=drop protocol=tcp src-address-list=VPN_blacklist dst-port=1723 log=no log-prefix=""
16 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=VPN_stage3 address-list=VPN_blacklist address-list-timeout=2w dst-port=1723
17 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=VPN_stage2 address-list=VPN_stage3 address-list-timeout=1m dst-port=1723 log=no
log-prefix=""
18 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=VPN_stage1 address-list=VPN_stage2 address-list-timeout=1m dst-port=1723 log=no
log-prefix=""
19 chain=input action=add-src-to-address-list connection-state=new protocol=tcp address-list=VPN_stage1 address-list-timeout=1m dst-port=1723 log=no log-prefix=""
20 ;;; ***allow PPTP port(s)
chain=input action=accept connection-state=new protocol=tcp dst-port=1723 log=yes log-prefix="PPTP>>>"
here the log output as i tested it on 3G and WiFi (successful connects via Wifi; VPN user = spippan_iphone)
13:03:28 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:62512->194.118.129.75:500, len 528
13:03:29 l2tp,info first L2TP UDP packet received from 213.162.68.132
13:03:29 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:56050->194.118.129.75:1701, len 96
13:04:22 l2tp,info first L2TP UDP packet received from 213.162.68.132
13:04:23 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:53121->194.118.129.75:1701, len 96
13:05:27 wireless,info F0:D1:A9:2F:9E:C6@WLAN: connected
13:05:50 wireless,info F0:D1:A9:2F:9E:C6@WLAN: disconnected, received disassoc: sending station leaving (8)
13:05:50 wireless,info WLAN: data from unknown device F0:D1:A9:2F:9E:C6, sent deauth
13:05:51 system,info ppp profile <VPN-sp> changed by spippan
13:05:59 l2tp,info first L2TP UDP packet received from 213.162.68.132
13:05:59 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:54479->194.118.129.75:1701, len 96
13:06:27 l2tp,info first L2TP UDP packet received from 213.162.68.132
13:06:27 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:65025->194.118.129.75:1701, len 96
13:06:39 system,info ppp profile <VPN-sp> changed by spippan
13:06:56 l2tp,info first L2TP UDP packet received from 213.162.68.132
13:06:56 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:61800->194.118.129.75:1701, len 96
13:07:28 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 81.189.xx.xx:500->194.118.129.75:500, len 528
13:07:28 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 81.189.xx.xx:4500->194.118.129.75:4500, len 140
13:07:29 l2tp,info first L2TP UDP packet received from 81.189.xx.xx
13:07:30 l2tp,ppp,info,account spippan_iphone logged in, 10.20.30.210
13:07:30 l2tp,ppp,info L2TP_spippan_iphone: authenticated
13:07:30 l2tp,ppp,info L2TP_spippan_iphone: connected
13:08:02 l2tp,ppp,info L2TP_spippan_iphone: terminating...
13:08:02 l2tp,ppp,info,account spippan_iphone logged out, 32 1534 207 10 6
13:08:02 l2tp,ppp,info L2TP_spippan_iphone: disconnected
13:08:03 system,info ipsec proposal default changed by spippan
13:08:11 l2tp,info first L2TP UDP packet received from 213.162.68.132
13:08:11 firewall,info L2TP>>> input: in:PPTP_A1_DSL out:(none), proto UDP, 213.162.68.132:64398->194.118.129.75:1701, len 96
13:08:37 system,info ipsec proposal default changed by spippan
13:08:43 pptp,info TCP connection established from 213.162.68.132
13:08:43 pptp,ppp,info,account spippan_iphone logged in, 10.20.30.210
13:08:43 pptp,ppp,info <pptp-spippan_iphone>: authenticated
13:08:44 pptp,ppp,info <pptp-spippan_iphone>: using encoding - MPPE128 stateless
13:08:45 pptp,ppp,info <pptp-spippan_iphone>: connected
13:09:31 system,info filter rule changed by spippan
13:09:33 pptp,ppp,info <pptp-spippan_iphone>: terminating... - disconnected
13:09:33 pptp,ppp,info,account spippan_iphone logged out, 50 1558 100 13 8
13:09:33 pptp,ppp,info <pptp-spippan_iphone>: disconnected
13:09:39 pptp,info TCP connection established from 213.162.68.132
13:09:39 firewall,info PPTP>>> input: in:PPTP_A1_DSL out:(none), proto TCP (SYN), 213.162.68.132:26799->194.118.129.75:1723, len 64
13:09:40 pptp,ppp,info,account spippan_iphone logged in, 10.20.30.210
13:09:40 pptp,ppp,info <pptp-spippan_iphone>: authenticated
13:09:40 pptp,ppp,info <pptp-spippan_iphone>: using encoding - MPPE128 stateless
13:09:41 pptp,ppp,info <pptp-spippan_iphone>: connected
13:10:50 wireless,info F0:D1:A9:2F:9E:C6@WLAN: connected
13:11:04 wireless,info F0:D1:A9:2F:9E:C6@WLAN: disconnected, received disassoc: sending station leaving (8)
13:11:04 wireless,info WLAN: data from unknown device F0:D1:A9:2F:9E:C6, sent deauth
13:11:55 pptp,ppp,info <pptp-spippan_iphone>: terminating...
13:11:55 pptp,ppp,info,account spippan_iphone logged out, 136 1558 100 13 8
13:11:55 pptp,ppp,info <pptp-spippan_iphone>: disconnected
13:12:06 system,info,account user spippan logged in from 10.20.30.200 via telnet
