Ipsec is working fine b/w mkt and openswan by following the example given on mkt website. but i have one issue with multiple lan subnets at openswan side didnt work. only one whose packet goes first esablish tunnel work and other didnt work. heres wat i have done..
mkt side
one WAN side on internet.
one peer connecting to openswan WAN side with 3des and md5
lan side pool 172.20.100.0/24 (src address)
2 same policies just a difference of destination address of openswan LAN
e.g one policy with dst address = 192.168.0.0/24 and other policy with dst address = 192.168.1.0/24 keeping the rest of the things same.
openswan side..
2 connection in ipsec conf keeping everything same except leftsubnet. one connection with 192.168.0.0/24 another connection with leftsubnet 192.168.1.0/24 keeping evrything same and ipsec securyt thr one shared key beczuse its connecting to the same global IP of mkt.
now here how its working…
when i ping from mkt lan that is 172.20.100.0/24 to any of the ip of Openswan LAN that is 192.168.1.0/24 or 192.168.0.0/24 it connects automatically and start pinging the other side sucessfully.
The Problem is, if in start I ping any ip of 192.168.0.0/24 from mkt lan 172.20.100.0/24 it connects using tunnel and encrption and start pinging 192.168.0.0/24 pool ips but not the 192.168.1.0/24 pool ips…
on the other hand if in start I ping any ip of 192.168.1.0/24 from mkt lan 172.20.100.0/24 it connects and start pinging but not the other subnet of openswan i.e 192.168.0.0/24 ..
it measn which packet goes first be4 connecting the tunnel is routed but it ignores the other policy … one at a time. and if i try to ping other subnet it gives error of ISAK key error on console of mkt. but if WAN IPs are same and secret is same both subnet shud be routed using the same key thr no keys in policy and conn config of either opnswan or mkt,
wat must be the prb and if anyone can tell me how to setup multiple subnet using ipsec tunnel and one peer. do i need to stablish another peer which i am doubtfull and how to ..
Regards
Fiz
