MTHOME - (WAN: x.x.x.10)
LAN (192.168.93.0/24)
server <----------(smtp-only)------> (through x.x.x.1) <----> CHR (WAN: x.x.x.1,x.x.x.2,x.x.x.3,x.x.x.4)
I have a CHR with 4 IP and a home router with a dynamic IP.
I have a mail server on the LAN. I need the mail server to communicate on the CHR’s IP (x.x.x.1), but only the traffic on port 25 should go that way. The rest of the traffic should use the MTHOME route.
I have set up an IPSEC tunnel with dst-nat and src-nat rules that works, but that case all network traffic goes through the tunnel, and that’s not what I want. I only need port 25 to use the IPSEC tunnel.
Okay, so these policies have a dst-port and an src-port attribute. You can add dst-port=25 to limit the packets that needs to be encapsulated and encrypted.
Don’t forget to update your NAT rules as well. You need to have a NAT rule that will masquerade all packets that were not encapsulated.
For example:
add chain=srcnat action=accept dst-port=25 dst-address=your.smtp.over.tunnel.address comment="bypass nat for packets that will be tunneled"
add chain=srcnat action=masquerade out-interface=your_wan_interface
Wow! Thanks for the help!
Works great! The only thing I have changed, that I had to change the src-port insted of dst-port for the policies. But that’s all!
