Good morning everyone.
I’m having trouble setting up a Mikrotik CCR in IPsec with Microsoft Azure. After configuring all the IPsec parameters, peer does not go up.
This error: ipsec: payload missing SA.
I enabled ipsec logging and this is the detail:
The configuration (cleaned of unnecessary data is this):
# 2024-05-26 13:50:00 by RouterOS 7.14.3
add comment="Bridge 1 for LAN 1 (Custom)" name="bridge1 - LAN1" \
port-cost-mode=short
add comment="Bridge 2 for LAN 2 (Custom)" disabled=yes name="bridge2 - LAN2" \
add name=WAN
add name=LAN
/ip ipsec profile
add dh-group=ecp256,modp2048,modp1024 enc-algorithm=aes-256,aes-128 name=\
"Profile Microsoft Azure (custom)" nat-traversal=no
/ip ipsec peer
add address=***********/32 comment="Org IP in Azure" exchange-mode=ike2 name=\
"Peer VPN Azure" profile="Profile Microsoft Azure (custom)"
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms=aes-256-cbc,aes-128-cbc \
lifetime=1h name="Proposal Azure (Custom)"
/interface detect-internet
set detect-interface-list=all
add comment="LAN Org (Custom)" interface="bridge1 - LAN1" list=LAN
add comment="WAN ISP (Custom)" interface="pppoe-out1 - ISP" list=WAN
add comment="LAN 2 - Lawal (Custom)" interface="bridge2 - LAN2" list=LAN
add address=10.0.0.254/24 comment="LAN - Router IP (custom)" interface=\
"bridge1 - LAN1" network=10.0.0.0
add address=192.168.120.11/24 comment="LAN 2 - IP Router (Custom)" disabled=\
yes interface="bridge2 - LAN2" network=192.168.120.0
add action=accept chain=srcnat comment="LAN to VPN Azure (Custom)" \
dst-address=192.168.1.0/24 src-address=10.0.0.0/24
add action=masquerade chain=srcnat comment="LAN to Internet (Custom)"
/ip ipsec identity
add comment="PSK in Azure (Custom)" peer="Peer VPN Azure"
/ip ipsec policy
add comment="Policy MS Azure DataCenter Virtual Network (custom)" \
dst-address=192.168.1.0/24 peer="Peer VPN Azure" proposal=\
"Proposal Azure (Custom)" src-address=10.0.0.0/24 tunnel=yes
add comment="Milan LAN (Custom)" disabled=yes dst-address=172.16.128.0/24 \
peer="Peer VPN Azure" src-address=10.0.0.0/24 tunnel=yes
add check-gateway=ping comment="LAN 2 Gw (Custom)" disabled=no distance=1 \
dst-address=192.168.120.0/24 gateway=192.168.120.11 pref-src="" \
routing-table=main suppress-hw-offload=no
add comment="Site Milan by Azure path for AD Sync (Custom)" disabled=yes \
distance=1 dst-address=10.0.0.0/24 gateway=******** pref-src="" \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
Has anyone already had a similar problem? What tests could I do to try to resolve it?
Thank you all
