I’m having some trouble getting phase two to work between an edgerouter and a MikroTik router and I could use some pointers.
Phase one connects but it can’t establish phase 2.
Any help would be much appreciated.
Edge router config:
set vpn ipsec esp-group FOO2 compression disable
set vpn ipsec esp-group FOO2 lifetime 3600
set vpn ipsec esp-group FOO2 mode tunnel
set vpn ipsec esp-group FOO2 pfs disable
set vpn ipsec esp-group FOO2 proposal 1 encryption aes256
set vpn ipsec esp-group FOO2 proposal 1 hash sha1
set vpn ipsec ike-group FOO2 ikev2-reauth no
set vpn ipsec ike-group FOO2 key-exchange ikev1
set vpn ipsec ike-group FOO2 lifetime 28800
set vpn ipsec ike-group FOO2 proposal 1 dh-group 14
set vpn ipsec ike-group FOO2 proposal 1 encryption aes256
set vpn ipsec ike-group FOO2 proposal 1 hash sha1set vpn ipsec site-to-site peer remote-site.name authentication mode pre-shared-secret
set vpn ipsec site-to-site peer remote-site.name authentication pre-shared-secret secretkey
set vpn ipsec site-to-site peer remote-site.name connection-type initiate
set vpn ipsec site-to-site peer remote-site.name description remote-site
set vpn ipsec site-to-site peer remote-site.name dhcp-interface eth0
set vpn ipsec site-to-site peer remote-site.name ike-group FOO2
set vpn ipsec site-to-site peer remote-site.name ikev2-reauth inherit
set vpn ipsec site-to-site peer remote-site.name tunnel 1 allow-nat-networks disable
set vpn ipsec site-to-site peer remote-site.name tunnel 1 allow-public-networks disable
set vpn ipsec site-to-site peer remote-site.name tunnel 1 esp-group FOO0
set vpn ipsec site-to-site peer remote-site.name tunnel 1 local prefix 192.168.0.0/24
set vpn ipsec site-to-site peer remote-site.name tunnel 1 remote prefix 192.168.1.0/24
MikroTik config
peer
address=1.1.1.1/32 auth-method=pre-shared-key secret=“secretkey” generate-policy=no policy-template-group=default exchange-mode=main send-initial-contact=yes nat-traversal=yes
proposal-check=obey hash-algorithm=sha1 enc-algorithm=aes-256 dh-group=ec2n185,ec2n155,modp8192,modp6144,modp4096,modp3072,modp2048,modp1536,modp1024,modp768 lifetime=1d
dpd-interval=2m dpd-maximum-failures=5
policy
src-address=192.168.1.0/24 src-port=any dst-address=192.168.0.0/24 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=2.2.2.2
sa-dst-address=1.1.1.1 proposal=default priority=0 ph2-count=0
