We have an ipsec tunnel between a CCR and a remote site using Strongswan. It’s configured to use NAT-T on port 4500, and everything works fine.
But once every hour we get 5-6 errors in the CCR log, mentioning timeout trying to negotiate phase1 from the standard IKE port 500.
This issue seems obvious, since we have not mentioned port 500 in any config and it should not be used..
How do I make the CCR initiate connections using port 4500?
17:28:12 ipsec,error phase1 negotiation failed due to time up [500]<=>[4500] 60c43a6d80bcaf6a:000000
17:29:22 ipsec,error phase1 negotiation failed due to time up [500]<=>[4500] 436282b6b2bb2b0e:000000
17:30:22 ipsec,error phase1 negotiation failed due to time up [500]<=>[4500] 960b27d6bf626da9:000000
/ip ipsec peer print
Flags: X - disabled, D - dynamic
0 address=/32 local-address= passive=no port=4500 auth-method=pre-shared-key secret=“” generate-policy=no
policy-template-group=default exchange-mode=main send-initial-contact=yes nat-traversal=yes proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des
dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
/ip ipsec remote-peers print
0 local-address= port=4500 remote-address= port=4500 state=established side=responder established=2m29s
