I am trying to get an IPSec tunnel working between my home and datacenter. I have set up the IPSec tunnel but nothing seems to happen. Nothing appears on under ‘Remote Peers’ or ‘Installed SAs’ on either side. I have enabled IPsec logging on one side and nothing appears:-
[admin-sy@scorpio] > / system logging print
Flags: X - disabled, I - invalid, * - default
# TOPICS ACTION PREFIX
0 * info memory
1 * error memory
2 * warning memory
3 * critical echo
4 pptp memory
5 script memory
6 X l2tp memory
7 ipsec memory
To test the connection I am using the built in ping tool to ping a local IP on the remote side but a single ping has never come back.
At home I have an RB751G-2HnD running v6.0rc11
At DC it is a virtualized x86 VM running v6.0rc11
Under IPSec peer I have tried nat-traversal=no and yes on both sides.
The config on both box’s is as follows:-
Home Router:-
[admin@scorpio] > /ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; default configuration
10.1.1.1/24 10.1.1.0 bridge-local
3 D 82.5.x.x/22 82.5.x.0 ether1-gateway
[admin@scorpio] > /ip ipsec policy print
Flags: X - disabled, D - dynamic, I - inactive
0 src-address=10.1.1.0/24 src-port=any dst-address=10.2.2.0/24 dst-port=any
protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes
sa-src-address=82.5.x.x sa-dst-address=82.147.x.x proposal=default
priority=0
[admin@scorpio] > /ip ipsec peer print
Flags: X - disabled
1 address=82.147.x.x/32 port=500 auth-method=pre-shared-key
secret="password" generate-policy=no exchange-mode=main
send-initial-contact=yes nat-traversal=no my-id-user-fqdn=""
proposal-check=obey hash-algorithm=md5 enc-algorithm=3des
dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=disable-dpd
dpd-maximum-failures=5
[admin@scorpio] > /ip ipsec proposal print
Flags: X - disabled, * - default
0 * name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
pfs-group=modp1024
[admin@scorpio] > /ip firewall filter print
2 chain=input action=accept src-address=82.147.x.x
3 chain=output action=accept dst-address=82.147.x.x
4 ;;; IPSec
chain=input action=accept connection-state=new protocol=udp dst-port=500
[admin@scorpio] > /ip firewall nat print
0 chain=srcnat action=accept src-address=10.1.1.0/24 dst-address=10.2.2.0/24
DC Router:-
[admin@cloudrouter] > /ip address print
0 ;;; WAN IP
82.147.x.x/26 82.147.x.0 wan
1 ;;; LAN IP
10.2.2.1/24 10.2.2.0 lan
[admin@cloudrouter] > /ip ipsec policy print
0 src-address=10.2.2.0/24 src-port=any dst-address=10.1.1.0/24 dst-port=any
sa-src-address=82.147.x.x sa-dst-address=82.5.x.x proposal=default
priority=0
[admin@cloudrouter] > /ip ipsec peer print
Flags: X - disabled
0 address=82.5.x.x/32 port=500 auth-method=pre-shared-key
[admin@cloudrouter] > /ip ipsec proposal print
pfs-group=modp1024
[admin@cloudrouter] > /ip firewall filter print
0 chain=input action=accept src-address=82.5.x.x
1 chain=output action=accept dst-address=82.5.x.x
2 ;;; IPSec
[admin@cloudrouter] > /ip firewall nat print
0 chain=srcnat action=accept src-address=10.2.2.0/24 dst-address=10.1.1.0/24
Can anybody see whats going wrong / things I can test / look out for?
