IPsec VPN tunnel established but no communication
Hi guys,
I’m having an issue with IPsec site to site with 2 Mikrotik with version 6.49.7 and 6.48.6.
Mikrotik-1 - does not have fixed public IP address
Mikrotik-2 - have pool of public ip addresses.
Mikrotik-1:
[admin@MikroTik] /ip ipsec active-peers> print
Flags: R - responder, N - natt-peer
ID STATE UPTIME PH2-TOTAL
0 established 3h22m52s 1
1
Mikrotik-2:
[admin@MikroTik] > ip ipsec active-peers print
0 RN established 3h23m44s 1
Connection is established but I cannot ping the remote devices.
Below are my configurations.
Mikrotik-1:
[admin@MikroTik] > ip ipsec policy print detail
 2   A  peer=Jupiter-Mikro tunnel=yes src-address=192.168.55.0/24 src-port=any
        dst-address=172.29.20.0/24 dst-port=any protocol=all action=encrypt
        level=unique ipsec-protocols=esp sa-src-address=192.168.100.10
        sa-dst-address=92.92.92.92 proposal=default ph2-count=2
[admin@MikroTik] > ip ipsec proposal print detail
 0  * name="default" auth-algorithms=sha1 enc-algorithms=aes-256-cbc lifetime=30m
      pfs-group=modp1024
 [admin@MikroTik] > ip ipsec peer print detail
 1     name="RemoteSite-Mikro" address=92.92.92.92/32 profile=default exchange-mode=main
       send-initial-contact=yes
[admin@MikroTik] > ip ipsec identity print detail
 1    peer=RemoteSite-Mikro auth-method=pre-shared-key
      secret="mysecretrsa" generate-policy=port-override
[admin@MikroTik] > ip ipsec profile print detail
 2   name="Profile-2" hash-algorithm=sha1 enc-algorithm=aes-128
     dh-group=modp2048,modp1024 lifetime=1d proposal-check=obey nat-traversal=no
     dpd-interval=2m dpd-maximum-failures=5
[admin@MikroTik] > ip ipsec active-peers print detail
 0    local-address=192.168.100.10 port=4500 remote-address=92.92.92.92 port=4500
      state=established side=initiator uptime=4h6m49s last-seen=19s ph2-total=1
      spii="71702b78fcf9b2e4" spir="c531e0454ac262f9"
[admin@MikroTik] > ip ipsec installed-sa print detail
Flags: H - hw-aead, A - AH, E - ESP
 0  E spi=0xE7E8CF8 src-address=92.92.92.92:4500 dst-address=192.168.100.10:4500
      state=mature auth-algorithm=sha1 enc-algorithm=aes-cbc enc-key-size=256
      auth-key="blabla"
      enc-key="blabla"
      add-lifetime=24m/30m replay=128
 1  E spi=0xC24A900 src-address=192.168.100.10:4500 dst-address=92.92.92.92:4500
      auth-key="blabla"
      enc-key="blabla"
[admin@MikroTik] > ip address print
 1   192.168.55.1/24    192.168.55.0    ether4-slave-local
 2   192.168.100.10/24  192.168.100.0   ether1-gateway
 3 D 192.168.100.2/24   192.168.100.0   ether1-gateway
[admin@MikroTik] > ip route print detail
 1 ADS  dst-address=0.0.0.0/0 gateway=192.168.100.1
        gateway-status=192.168.100.1 reachable via  ether1-gateway distance=1 scope=30
        target-scope=10 vrf-interface=ether1-gateway
 2   S  dst-address=0.0.0.0/0 gateway=192.168.100.1
        target-scope=10
 3 ADC  dst-address=192.168.55.0/24 pref-src=192.168.55.1 gateway=ether4-slave-local
        gateway-status=ether4-slave-local reachable distance=0 scope=10
 6 ADC  dst-address=192.168.100.0/24 pref-src=192.168.100.10 gateway=ether1-gateway
        gateway-status=ether1-gateway reachable distance=0 scope=10
[admin@MikroTik] > ip firewall filter print detail
 0    ;;; vpn
      chain=input action=accept protocol=tcp dst-port=1723 log=no log-prefix=""
 1    chain=input action=accept protocol=gre log=no log-prefix=""
 2    chain=input action=accept protocol=udp in-interface=ether1-gateway dst-port=500
 3    chain=input action=accept protocol=udp in-interface=ether1-gateway dst-port=4500
 4    chain=forward action=accept src-address=172.29.20.0/24 dst-address=192.168.55.0/24
 5    chain=input action=accept src-address=192.168.55.0/24 dst-address=172.29.20.0/24
      log=yes log-prefix=""
 6    chain=forward action=drop layer7-protocol=Facebook&youtube protocol=tcp
      in-interface=ether4-slave-local out-interface=ether1-gateway dst-port=80,443
 7    ;;; default configuration
      chain=input action=accept protocol=icmp log-prefix=""
 8    ;;; default configuration
      chain=input action=accept connection-state=established log-prefix=""
 9    ;;; default configuration
      chain=input action=accept connection-state=related log-prefix=""
10    ;;; default configuration
      chain=input action=drop in-interface=ether1-gateway log=no log-prefix=""
11    ;;; default configuration
      chain=forward action=accept connection-state=established log-prefix=""
12    ;;; default configuration
      chain=forward action=accept connection-state=related log-prefix=""
13    ;;; default configuration
      chain=forward action=drop connection-state=invalid log=no log-prefix=""
[admin@MikroTik] > ip firewall nat print detail
      chain=srcnat action=masquerade out-interface=ether1-gateway log-prefix=""
 2    chain=srcnat action=accept src-address=192.168.55.0 dst-address=172.29.20.0/24 log=no log-prefix=""
Mikrotik-2:
 1  DA  peer=Office tunnel=yes src-address=172.29.20.0/24 src-port=any
       dst-address=192.168.55.0/24 dst-port=any protocol=all action=encrypt
       level=unique ipsec-protocols=esp sa-src-address=92.92.92.92
       sa-dst-address=12.119.186.238 proposal=default ph2-count=1
Flags: X - disabled, * - default
      pfs-group=modp1024
Flags: X - disabled, D - dynamic, R - responder
 0   R name="Office" passive=yes profile=default exchange-mode=main
       send-initial-contact=no
Flags: D - dynamic, X - disabled
 0    peer=CEC auth-method=pre-shared-key secret="mysecretrsa"
Flags: * - default
 0 * name="default" hash-algorithm=sha1 enc-algorithm=aes-128
     nat-traversal=yes dpd-interval=2m dpd-maximum-failures=5
 0 RN local-address=92.92.92.92 port=4500 remote-address=102.119.186.238
      port=21278 state=established side=responder uptime=4h27m16s last-seen=43s
      ph2-total=2
 0  E spi=0xC24A900 src-address=12.119.186.238:21278 dst-address=92.92.92.92:450>
      state=dying auth-algorithm=sha1 enc-algorithm=aes-cbc enc-key-size=256
      auth-key="blabla"
      enc-key="blabla"
 1  E spi=0xE7E8CF8 src-address=92.92.92.92:4500 dst-address=12.119.186.238:2127>
      auth-key="blabla"
      enc-key="blabla"
 2  E spi=0x772AC35 src-address=12.119.186.238:21278 dst-address=92.92.92.92:450>
      auth-key="blabla"
      enc-key="blabla"
 3  E spi=0x9D2CADC src-address=92.92.92.92:4500 dst-address=12.119.186.238:2127>
      auth-key="blabla"
      enc-key="blabla"
 #   ADDRESS            NETWORK         INTERFACE
 0   15.11.15.21/26 15.11.15.12 ether1
 1   172.29.20.1/24     172.29.20.0     ether2
 2   92.92.92.92/28      92.92.92.91      ether3
 3   172.16.0.1/32      172.16.0.1      Loopback
 0 A S  dst-address=0.0.0.0/0 gateway=135.181.165.193
        gateway-status=15.11.15.13 reachable via  ether1 distance=1
        scope=30 target-scope=10
 1 ADC  dst-address=92.92.92.91/28 pref-src=92.92.92.92 gateway=ether3
        gateway-status=ether3 reachable distance=0 scope=10
 2 ADC  dst-address=15.11.15.12/26 pref-src=15.11.15.21 gateway=ether1
        gateway-status=ether1 reachable distance=0 scope=10
 3 ADC  dst-address=172.16.0.1/32 pref-src=172.16.0.1 gateway=Loopback
        gateway-status=Loopback reachable distance=0 scope=10
 4 ADC  dst-address=172.29.20.0/24 pref-src=172.29.20.1 gateway=ether2
        gateway-status=ether2 reachable distance=0 scope=10
 0    ;;; Mikrotik Access rule
      chain=input action=accept src-address-list=CountryIPBlocks log=no
      log-prefix=""
 3    chain=forward action=accept connection-state=established,related,untracked
18    ;;; Mikrotik
      chain=forward action=accept dst-address=92.92.92.92 in-interface=ether1
19    ;;; Block-All-TCP
      chain=forward action=drop protocol=tcp dst-address=92.92.92.92/28
      in-interface=ether1 log=yes log-prefix=""
22    ;;; Deny ALL rule
      chain=input action=reject reject-with=icmp-host-prohibited log=yes
      log-prefix=""
 0    chain=srcnat action=masquerade src-address=172.29.20.0/24
      out-interface=ether1 log=no log-prefix=""
 1    chain=srcnat action=masquerade src-address=172.16.0.1 out-interface=ether1
Thanks to help.
Order of rules matters. On Mikrotik-1 swap your two srcnat rules. On Mikrotik-2 add something similar (the one with action=accept). Or you can get rid of them and add ipsec-policy=out,none to masquerade rules.
Hi Sob, thanks for the reply.
Mikrotik-1:
 1    chain=srcnat action=accept src-address=192.168.55.0 dst-address=172.29.20.0/24
[admin@MikroTik] >
Mikrotik-2:
 0    chain=srcnat action=accept src-address=172.29.20.0/24 dst-address=192.168.55.0
 1    chain=srcnat action=masquerade src-address=172.29.20.0/24 out-interface=ether1
 2    chain=srcnat action=masquerade src-address=172.16.0.1 out-interface=ether1 log=no
      log-prefix=""
Not sure, if this what you are trying to say and it did not work. Can you explain better or if possible put the code.
I made a traceroute and it drops after my internet router.
This problem is well documenteds in the already available resources
You need to clear the contrack table after making this type of change.
It’s almost right, only I missed one important detail:
192.168.55.0 = 192.168.55.0/32 = single address (you have this now)
192.168.55.0/24 = whole subnet (you want to have this)
Or the other way, where those rules wouldn’t be needed at all, would be changing existing masquerade:
chain=srcnat action=masquerade out-interface=ether1-gateway ipsec-policy=out,none
And similar on second router.
Hi Sob & Smyers. Thanks guys.
It worked. This is how it is incase someone face such problem.
Mikrotik-1:
0    chain=forward action=accept connection-state=established,related
      src-address=172.29.20.0/24 dst-address=192.168.55.0/24 log=no log-prefix=""
 1    chain=forward action=accept connection-state=established,related
      src-address=192.168.55.0/24 dst-address=172.29.20.0/24 log=yes log-prefix=""
  0    chain=srcnat action=accept src-address=192.168.55.0/24 dst-address=172.29.20.0/24
Mikrotik-2:
0    chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
 1    chain=srcnat action=accept src-address=172.29.20.0/24 dst-address=192.168.55.0/24
