IPTV Problem
Hi All
thanks to the developers for creating snooping, but I still have problems in viewing channels in HD quality via a wireless network, they simply do not appear, although the usual channels are perfectly displayed, is configured capsman, the multicast helper is configured in full, tell what you can do to HD channels display correctly when connected via Wi Fi
help me please
is your wireless network bridged together with the wired LAN?
do the mentioned HD channels work in the wired environment?
can you draw just a brief topology of your networking setup? be sure to mention where is the multicast coming from.
can you post the relevant configuration of your router/ap?
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled frequency=2412
name=channel1 tx-power=18
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=Ce frequency=5180
name=channel2 tx-power=18
add admin-mac=4C:5E:0C:34:C9:F5 auto-mac=no fast-forward=no igmp-snooping=yes name=
bridge-local
/interface wireless
managed by CAPsMAN
channel: 2412/20/gn(18dBm), SSID: Ra, local forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=russia
disabled=no distance=indoors frequency=auto mode=ap-bridge multicast-helper=full
ssid=Ra tx-power=19 tx-power-mode=all-rates-fixed wireless-protocol=802.11
wmm-support=enabled
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] name=ether3-slave-local
set [ find default-name=ether4 ] name=ether4-slave-local
set [ find default-name=ether5 ] name=ether5-slave-local
/interface pptp-server
add name=pptp-in1 user=olo
/interface gre
add allow-fast-path=no clamp-tcp-mss=no disabled=yes !keepalive mtu=1500 name=
gre-tunnel1-deer remote-address=82.00.0.10
/interface eoip
add allow-fast-path=no clamp-tcp-mss=no !keepalive mac-address=02:93:4A:55:DF:10 mtu=1500
name=eoip-tunnel1 remote-address=95.0.46.00 tunnel-id=55
add !keepalive mac-address=02:54:ED:87:8D:76 mtu=1500 name=eoip-tunnel2 remote-address=
176.0.99.00 tunnel-id=56
add !keepalive local-address=10.1.1.1 mac-address=02:FD:7F:68:6A:89 mtu=1500 name=
eoip-tunnel3 remote-address=10.1.1.2 tunnel-id=57
/caps-man datapath
add bridge=bridge-local local-forwarding=yes name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=
security1 passphrase=123
/caps-man configuration
add channel=channel1 datapath=datapath1 mode=ap multicast-helper=full name=cfg1
rx-chains=0,1,2 security=security1 ssid=Ra tx-chains=0,1,2
add channel=channel2 datapath=datapath1 mode=ap multicast-helper=full name=cfg2
rx-chains=0,1,2 security=security1 ssid="Ra 5GHz" tx-chains=0,1,2
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=123
wpa2-pre-shared-key=123
/ip firewall layer7-protocol
add name=social regexp="^.(vk.com).$"
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.101-192.168.88.200
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local
name=default
/queue simple
total-queue=default
/caps-man access-list
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=b,gn master-configuration=cfg1
add action=create-dynamic-enabled hw-supported-modes=an,ac master-configuration=cfg2
/interface bridge filter
add action=drop chain=forward comment="Drop all DHCP requests over EoIP bridge" dst-port=
67 ip-protocol=udp mac-protocol=ip
add action=drop chain=forward dst-port=67 ip-protocol=udp mac-protocol=ip
add action=drop chain=output disabled=yes out-interface=wlan1 packet-type=multicast
add action=drop chain=output disabled=yes out-interface=eoip-tunnel1 packet-type=
multicast
add action=drop chain=output disabled=yes out-interface=eoip-tunnel2 packet-type=
multicast
add action=drop chain=output disabled=yes out-interface=*14 packet-type=multicast
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local hw=no interface=wlan1
add bridge=bridge-local hw=no interface=eoip-tunnel1
add bridge=bridge-local hw=no interface=eoip-tunnel2
add bridge=bridge-local hw=no interface=eoip-tunnel3
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local interface=ether4-slave-local
add bridge=bridge-local interface=ether5-slave-local
/interface l2tp-server server
set ipsec-secret=kandrat
/interface pptp-server server
set default-profile=default enabled=yes
/interface sstp-server server
set default-profile=default-encryption
/interface wireless access-list
/interface wireless cap
set bridge=bridge-local caps-man-addresses=192.168.88.1 enabled=yes interfaces=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=ether2-master-local
network=192.168.88.0
add address=176.197.0.0/30 interface=ether1-gateway network=176.0.20.0
add address=2.2.2.3/24 interface=gre-tunnel1-deer network=2.2.2.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=
ether1-gateway
/ip dhcp-server lease
add address=192.168.88.0/24 comment="default configuration" gateway=192.168.88.1 netmask=
24
set allow-remote-requests=yes servers=212.00.200.62,212.00.211.0
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=192.168.88.109 list=dumnies
add address=192.168.88.119 list=dumnies
add action=accept chain=input in-interface=ether1-gateway protocol=igmp
add action=accept chain=forward dst-port=1234 in-interface=ether1-gateway protocol=udp
add action=accept chain=input dst-port=1234 in-interface=ether1-gateway protocol=udp
add action=reject chain=forward comment="Blocked Social Sites" dst-port=80
layer7-protocol=social protocol=tcp reject-with=tcp-reset src-address-list=dumnies
add action=reject chain=forward dst-port=443 layer7-protocol=social protocol=tcp
add action=drop chain=forward comment="viber" disabled=yes dst-address=
52.0.252.0/22 src-address=192.168.88.129
add action=drop chain=forward comment="jungleheat" dst-address=185.30.176.211
185.30.176.211 src-address=192.168.88.148
52.0.252.0/22 src-address=192.168.88.131
add action=drop chain=forward comment="kdv" dst-address=185.98.85.30 src-address=
192.168.88.131
add action=drop chain=forward comment="magnit" dst-address=193.19.171.200
add action=accept chain=forward comment="default configuration" connection-state=
established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=
!dstnat connection-state=new in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=
ether1-gateway
add action=dst-nat chain=dstnat dst-port=10853 in-interface=ether1-gateway protocol=tcp
to-addresses=192.168.88.111 to-ports=10853
add action=dst-nat chain=dstnat dst-port=6308 in-interface=ether1-gateway protocol=udp
to-addresses=192.168.88.111 to-ports=6308
add action=dst-nat chain=dstnat dst-port=50999 in-interface=ether1-gateway protocol=tcp
to-addresses=192.168.88.111 to-ports=50999
add action=dst-nat chain=dstnat dst-port=5651 in-interface=ether1-gateway protocol=tcp
add action=dst-nat chain=dstnat comment="RDP Server" disabled=yes dst-port=46664
in-interface=ether1-gateway protocol=tcp to-addresses=192.168.88.104 to-ports=3389
add distance=1 gateway=176.1.1.1
add distance=1 dst-address=192.168.0.0/24 gateway=2.2.2.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb
set allow-guests=no domain=WORKGROUP interfaces=bridge-local
/ip smb shares
add directory=/disk1 max-sessions=50 name=files
/ip smb users
add name=admin password=admin read-only=no
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=ether3-slave-local type=internal
add interface=ether1-gateway type=external
/ppp secret
add local-address=10.1.1.1 name=olo password=123 remote-address=10.1.1.2 service=
pptp
/routing igmp-proxy
set query-interval=1s query-response-interval=1s quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=ether1-gateway upstream=yes
add interface=bridge-local
/system clock
set time-zone-name=Asia/Novokuznetsk
/system identity
set name=RA
/system leds
set 0 interface=wlan1
/system logging
set 0 topics=info,!dhcp,!caps
Quite the config.
I kind of doubt it will help much, but I noticed your lan ip is configured on Ether2 instead of the Bridge. This can sometimes cause issues, but I don’t know if it would slow down things too much to interfere with HD vs SD throughput. Should be worth the try though.
