IPTV
our network of 25 computers and 1 console ror IPTV
startup problems begin consoles
winbox does not respond, router rebooted by watchdog, user user SQL not respond
when will it work? Why should I put multiple routers for normal ??
I will write about this problem EVERY DAY until you decide to choose.
I’m tired of these network problems.
п.с.
может банить менять хоть милион раз, я все равно найду способ сюда зайти, прокси никто не отменял
I am afraid you haven’t described any problem, just that the router was rebooted by the watchdog. It could be even correct, none knows how you have set it.
supout.rif send 16/05/2016
Ticket#2016051666000086
we don’t have access to your conversations with Support :slight_smile:
it’s community forum, we are just people like you. if you need an answer from support - write to support@mikrotik.com
I do not need your advice , I need an official response , when there will be the realization of a normal iptv
Then why do you post to the forum?
And do you think it is somehow our fault, and we have to hear about your issues every day?
Write to support, not here. As said, this is an user forum.
if reading my posts , you would see that the support staff does not respond to them
helpdesk, instead of helping to block my ip adress in this forum
And this makes it OK to threat us with post flooding? Please think again.
This is an issue between you and Mikrotik, not with us.
If you need user help, other users may be glad to offer it. If not, don’t post, that is your choice, but refrain from dragging us in your war on this forum.
at the moment I do not see help users and answer mikrotik
At the moment we read complaints of the grumbler. If you want help from us just ask for it.
nobody forces you to read it
2016051666000086 ticket was answered.
The email says that we don’t have IGMP snooping and that we may work on it in future.
That’s an official response.
and more concrete? in a year, two? or three?
In these cases is official answer always the same: when it will be then it will be. If you are not willing to wait, obtain devices of other manufacturers that are you sure will provide whole set of features you need.
there are exceptions in all of rules, therefore I ask to do an exception and name exemplary terms though
As It was determined in other topics you created, you don’t even need feature you are requesting. IGMP snooping is for switches, but you are trying to route Multicast streams over your router, in this case IGMP-proxy should be used which RouterOS already supports.
mikroik routers don’t have switch processors?
what is the point of the question?
Thay do have. Why are you asking ? Are you suprised that router is not all-in-one solution ?
If the lownmower has an engine it does not implies that it could be used as a car.
