I have an RB5009 and im trying to configure IPV6 along with IPV4 with VLANs
VLANS are tagged on my APs depending on which WiFi client is connected to.
I would like to have IPV6 set up as well, but im stuck.
Problem is that Network Discovery does not work with my current config, and im not even able to reach the router from a machine configured with a static IPV6.
This is my current config:
2026-02-26 09:21:59 by RouterOS 7.21.3
# model = RB5009UPr+S+
add admin-mac=xx arp=proxy-arp auto-mac=no comment=defconf
name=bridge
set \[ find default-name=ether1 \] l2mtu=1514
set \[ find default-name=ether2 \] l2mtu=1514
set \[ find default-name=ether3 \] l2mtu=1514
set \[ find default-name=ether4 \] l2mtu=1514
set \[ find default-name=ether5 \] l2mtu=1514
set \[ find default-name=ether6 \] l2mtu=1514
set \[ find default-name=ether7 \] l2mtu=1514
set \[ find default-name=ether8 \] l2mtu=1514
set \[ find default-name=sfp-sfpplus1 \] l2mtu=1514
/interface vlan
add comment="Guest VLAN" interface=bridge name=guestvlan vlan-id=30
add comment="Party VLAN" interface=bridge name=party-vlan vlan-id=60
add arp=proxy-arp comment="Private VLAN" interface=bridge name=privatevlan
vlan-id=10
add comment="WAN VLAN" interface=sfp-sfpplus1 name=vlan101 vlan-id=101
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=private_pool ranges=192.168.1.10-192.168.1.99
add name=guest_pool ranges=192.168.30.2-192.168.30.100
add name=OVPN-pool ranges=192.168.8.100-192.168.8.200
add name=party_pool ranges=192.168.60.2-192.168.60.254
add address-pool=private_pool interface=bridge lease-time=1h name=defconf
add address-pool=guest_pool interface=guestvlan lease-time=1h name=guestdhcp
add address-pool=party_pool interface=party-vlan name=partydhcp
/ppp profile
set *FFFFFFFE bridge=bridge change-tcp-mss=default dns-server=192.168.1.250
interface-list=LAN local-address=192.168.8.1 remote-address=OVPN-pool
use-ipv6=default
/system logging action
set 3 remote=192.168.1.250
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus1
add bridge=bridge interface=ether1
set udp-timeout=10s
add interface=vlan101 list=WAN
add disabled=yes interface=sfp-sfpplus1 list=WAN
/interface ovpn-server server
add certificate=server-cert cipher=
aes128-cbc,aes192-cbc,aes256-cbc,aes128-gcm,aes192-gcm,aes256-gcm
default-profile=default-encryption disabled=no mac-address=
FE:BF:68:5C:0E:25 name=ovpn-server1 port=1199 redirect-gateway=def1
require-client-certificate=yes
/interface wireguard peers
add allowed-address=192.168.10.2/32 interface=16 name=peer1 public-key=
add address=192.168.1.1/24 comment=defconf interface=bridge network=
192.168.1.0
add address=192.168.30.1/24 interface=guestvlan network=192.168.30.0
add address=89.150.130.82 interface=vlan101 network=89.150.130.82
add address=192.168.60.1/24 interface=party-vlan network=192.168.60.0
/ip dhcp-client
add comment=defconf dhcp-options=clientid_duid,clientid_duid interface=
vlan101
/ipv6 address
add address=::1:0:0:0:1 from-pool=isp-ipv6 interface=privatevlan
add address=::3:0:0:0:1 from-pool=isp-ipv6 interface=guestvlan
add address=::6:0:0:0:1 from-pool=isp-ipv6 interface=party-vlan
/ipv6 dhcp-client
add add-default-route=yes interface=vlan101 pool-name=isp-ipv6 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" disabled=yes
in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
/ipv6 nd
set \[ find default=yes \] disabled=yes
add advertise-dns=yes interface=privatevlan other-configuration=yes
add advertise-dns=yes interface=guestvlan other-configuration=yes
add advertise-dns=yes interface=party-vlan other-configuration=yes
