thank you mrz. so what’s a possible solution?
I have other peers which allow BGP through a /126 or /127 ptp, but this one provider is not going to allow me.
I’d say Recusive routing is totally broken for ipv6 in RosV6 having route coming in from ospfv3 process, ibgp session but MP bgp route can’t get active because the gateway is unreachable according to the ipv6 route print where active (none) and print detail tells gateway unreachable, ping gateway from same cli works like a charm and is a globaly uninqe adress on a router several hops away.
So as we now have it. RouterOS can’t be used for ipv6 and this is what holding us back implementing ipv6. FIX NOW!
I do not run the latest bugfix version on the router mentioned here but I have Also not seen anything in release notes stating that it would work with a later version.
Unfortunately it looks like the IPv6 engineer at MikroTIk has retired or is on extended leave.
Some minor display issues aside, there have been no changes in IPv6 for a year and a half, and no appreciable feature changes for several years.
Even the features that have changed (the announcement of DNS via RA) are in a half-baked state.
New features introduced usually lack IPv6 support. It looks like IPv6 is not a topic at MikroTik, unfortunately.
