Is a ipv6 configuration with a mikrotik router possible just with this information? How should a configuration look like? If I try to get a ipv6 with DHCPv6 Client it’s just “searching” and nothing else.
Any tips for the configuration? Thanks!
thanks. I configured this but I cant ping any IPv6 outside our network. Even if I try to ping the GW. Maybe there is something wrong with their configuration. Firewall Rules are default.
at most you have to ask for a IPv6 pool, not just one IPv6…
/ipv6 dhcp-client
add interface=pppoe-out1 pool-name=pool rapid-commit=no request=prefix
Withiut have network description and one /export of your actual configuration, the help can be only approximative.
set cache-max-ttl=30m servers=1.1.1.1,8.8.8.8,2606:4700:4700::1111,2001:4860:4860::8888
/ipv6 pool
add name=pool prefix=2a00:3:xxxx::/48 prefix-length=64
@pe1chl Shouldn’t the default route be of distance >0, e.g.
@lordimac When you say that you cannot ping, do you receive an ICMPv6 error or get a timeout?
I do no know what are the default ipv6 firewall rules on RouterOS, can you post them? Or, even do “/ipv6 export hide-sensitive”
I would try to sniff on the WAN port to see if there are any IPv6 packets coming from the upstream at all.
@rextended: I tried your recommended configuration as well. Same problem. And sorry for the misunderstanding in my initial post, I trtied to search for an prefix as well without success.
ping 2001:4860:4860::8888
PING 2001:4860:4860::8888(2001:4860:4860::8888) 56 data bytes
From 2a00:0:a028:1:de2c:6eff:fe41:4a41 icmp_seq=1 Destination unreachable: Address unreachable
From 2a00:0:a028:1:de2c:6eff:fe41:4a41 icmp_seq=2 Destination unreachable: Address unreachable
From 2a00:0:a028:1:de2c:6eff:fe41:4a41 icmp_seq=3 Destination unreachable: Address unreachable
From 2a00:0:a028:1:de2c:6eff:fe41:4a41 icmp_seq=4 Destination unreachable: Address unreachable
Traceroute to Google DNS IPv6:
traceroute to 2001:4860:4860::8888 (2001:4860:4860::8888), 30 hops max, 80 byte packets
1 2a00:0:a028:1:de2c:6eff:fe41:4a41 (2a00:0:a028:1:de2c:6eff:fe41:4a41) 0.613 ms 0.563 ms 0.533 ms
2 2a00:0:a028:1:de2c:6eff:fe41:4a41 (2a00:0:a028:1:de2c:6eff:fe41:4a41) 3143.252 ms !H 3143.238 ms !H 3143.183 ms !H
Ping to GW from my provider (according to their informations):
ping 2a00:3:xxxx::1
PING 2a00:3:xxxx::1(2a00:3:xxxx::1) 56 data bytes
From 2a00:3:xxxx:0:250:56ff:fe80:a94f icmp_seq=2 Destination unreachable: Address unreachable
From 2a00:3:xxxx:0:250:56ff:fe80:a94f icmp_seq=3 Destination unreachable: Address unreachable
From 2a00:3:xxxx:0:250:56ff:fe80:a94f icmp_seq=4 Destination unreachable: Address unreachable
(I masked a part of our prefix with xxxx because of paranoia. )
do not have same axpect…
/ipv6 route
add distance=10 dst-address=2000::/3 gateway=fe80:remo:teli:nklo:cal%interfacename
open the ipv6 / neighbors and read the fe80::xxxx:xxxx:xxxx:xxx address that have the ISP interface, on the other side of ether1,
and combine something like: gateway=fe80::xxxx:xxxx:xxxx:xxx%ether1
Hello, just a short remark. The support of my provider is checking their IPv6 config in their routers. To be clear, we are using 2 fibre connections which are combined (HSRP.) The virtual HSRP interface is providing IPv4 perfectly, but not IPv6. At the moment we think thats the problem, because both routers are recognized by ND with their link-local address but not the virtual HSRP interface.
