Ipv6, how am I getting deprecated address?
Having only one prefix
/ipv6/nd/prefix/print
Flags: X - DISABLED, I - INVALID; D - DYNAMIC
0  D prefix=2a01:36d:1000:8e4::/64 6to4-interface=none interface=ether1 on-link=yes autonomous=yes dhcp6-pd-preferred=no valid-lifetime=1w4h preferred-lifetime=1w4h
Fresh start of my Windows PC (but it is the same on macOS, Synology…)
Get-NetIPAddress | ft
ifIndex IPAddress                                       PrefixLength PrefixOrigin SuffixOrigin AddressState PolicyStore
3       2a01:36d:1000:aec:xxxx:xxxx:xxxx:xxxx                      64 RouterAdv... Link         Deprecated   ActiveStore
3       2a01:36d:1000:8e4:xxxx:xxxx:xxxx:xxxx                      64 RouterAdv... Link         Preferred    ActiveStore
Why do I get the 2a01:36d:1000:aec:xxxx:xxxx:xxxx:xxxx address? From where does it come?
Check what addresses are assigned to your LAN bridge interface and if they have advertise enabled.
If it's deprecated, it may be leftover from a previous configuration.
I see only 2a01:36c:1000:8e4:: addresses
/ipv6/address/print
Flags: D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, FROM-POOL, INTERFACE, VRF, ADVERTISE, VALID, PREFERRED
#    ADDRESS                              FROM-POOL  INTERFACE   VRF   ADVERTISE  VALID      PREFERRED
0  G 2a01:36d:1000:8e4::/64               ipv6pool   ether1      main  yes
1 DL fe80::x:x:x:x/64                                wireguard1  main  no
2 DL fe80::x:x:x:x/64                                pppoe-out1  main  no
3 DG 2a01:36c:1000:8e4:x:x:x:x/64                    pppoe-out1  main  no         23h50m28s  3h50m28s
4 D  ::1/128                                         lo          main  no
5 DL fe80::x:x:x:x/64                                ovpn-out1   main  no
6 DL fe80::x:x:x:x/64                                ether1      main  no
7 DL fe80::x:x:x:x/64                                ether5      main  no
8 DG 2a01:36c:1000:8e4:x:x:x:x/128                   pppoe-out1  main  no
At some point since the router last booted the ISP gave you the prefix that is now deprecated, which was replaced by your current prefix, probably because of a wan reconnect or something, and now it's advertised as deprecated so that the clients won't try to use it anymore.
What's the issue?
My issue is, that I cannot find this prefix in the router any more, in my interpretation should not be advertised. I already did dhcpv6client release/renew, disable/enable, global address disable/enable, I simply do not see why would the old prefix still be there in the router and advertised…
If it was there it wouldn't be advertised as deprecated, it was there at some point though.
I don't know for how long MikroTIk advertises deprecated prefixes though, they added this in recent versions and I didn't study the behaviour enough, yet.
You shouldn't care about it.
The “deprecated” advert means “this address used to be valid but now it isn’t anymore”.
Clients systems should use that to erase it from their config. Unfortunately, buggy client systems exist that do not check this field and use it as “preferred”…
Probably a reboot of the router, or elapse of the usual valid time (24h in your case?) will make it go away.
Does not help that
/ipv6/nd/prefix/default/print
          autonomous: yes
  dhcp6-pd-preferred: yes
      valid-lifetime: 2h
  preferred-lifetime: 30m
values are simply disregarded, I had just now a prefix change forced by the ISP, and the new prefix was created with
 0  D prefix=2a01:36d:1000:30d7::/64 6to4-interface=none interface=ether1 on-link=yes autonomous=yes dhcp6-pd-preferred=yes valid-lifetime=1w4h preferred-lifetime=1w4h
So, I presume ipv6 is buggy everywhere…
This is due to the change introduced with 7.21:
From that version, the lifetime values you set in the default settings are ignored, and the lifetime is taken from the pool, which in turn gets the values from the ISP DHCPv6 lease (binding).
I've complained about this change in the RC thread, because the problem is even worse when the router is rebooted.
I've also suggested multiple times that they use the smaller value between the default that we set on the router and the value sent by the ISP as lifetime used by the advertisements, but alas, it was in vain.
Did you file a bug report for this?
I've just noticed this on an ISP that sends me a prefix valid for 25 hours. x.x
Not yet, but definitely will as soon as I have the time. It instantly breaks my rustdesk system. I do update my ddns, but even if I have a powershell script to remove all other ipv6 addresses, they crawl back later…
Addresses marked as Deprecated are not supposed to be used by systems and/or programs. Probably some bad programming there. idk. MikroTik does the job of marking them as deprecated.
The bug report I was talking about was about the inability to override the ISP provided lifetime.
No, I did not submit a support ticket. Apparently, the beta & RC threads are supposed to be read by some MikroTik staffs, and we are supposed to raise any issues encountered with the version being developed in those threads. But for this case, they probably won't consider changing the introduced behavior.
In that thread I also suggested the real fix for the problem (bad preferred prefix after reboot) V7.21rc [testing] is released! - #41 by CGGXANNX, that even got 12 "thumb-ups", but MikroTik seem not interested by that idea either.
The problem is only bad for Windows clients (I don't know about Apple devices though), Linux and Android, although listing multiple IPv6 addresses as preferred, will pick the more recent address for new connections and has no connectivity issue (unlike Windows).
I did file a bug report about the inability to alter the prefix lifetimes provided by the ISP (if they are aren't set to "forever"), we'll see.
When I was hunting down a problem, I found that old versions of Windows and also Windows PE had a problem, but current updated versions did not. I do not know if the Windows PE included on Windows 11 install CDs has been fixed by now. Usually a worse problem with Windows is that it takes IPv6 addresses from other VLANs, when you have plugged a Windows PC in a port that has the default network untagged and other networks tagged. That is because of the stupid way of handling VLANs in Windows.
Yeah, that is due to the default settings of the network adapter drivers. But if the "Priority & VLAN" setting is set correctly in the adapter driver properties, then it filters out the tagged VLANs fine.
On Windows I normally enable the Hyper-V Platform (which BTW is also possible for the Home Edition), then let Hyper-V take over the network adapters. With Hyper-V virtual switches / adapters full support for tagged VLANs is available.
