I’m trying to setup my Mikrotik the best way, and I’m satisfied with it… Unless by the fact IPv6 doesn’t work properly.
I already setup, and Mikrotik sees my IPv6, I can ping out from mikrotik, etc. My devices connected also gets his IPv6… Until my session PPPoE renew itself (my ISP force the session to renew automatically every 48h), in this case, Mikrotik gets a new Prefix, but it is NOT advertising to my network (until I force it releasing and renewing on device).
When it happens, if I try to ping out (an IPv6 adress) from Mikrotik, it replies perfectly. If I try on my wired computer, it doesn’t! (as I said, unless if I reboot the computer, or disable my ethernet, and re-enabling later).
I really don’t know what can I do to fix this. It’s the only problem I didn’t fix yet.
P.S.: if I turn off my Mikrotik and create same scenario in my Archer C7, everything works FLAWLESSLY. Even if the PPPoE renews, devices automatically gets new IPv6, everything works.
I’mma try this, but, when I used to use OpenWRT/LEDE, IPv6 automatically changed in every device when PPPoE session renewed.
Is that as ND lifetime in OpenWRT was 10s (for example)?
I changed the values you said, force the renewing, but it didn’t advertise.
I look into Neighbor List, the public IPs isn’t being advertised, only if I disable my wifi (if the device is a smarthphone), or my ethernet (pc wired), forcing the new IP
The most problem with IPv6 on renew on devices is related to the lifetime of the prefix when use MikroTik.
You can also low the ra-lifetime to 15m.
I don’t remember how is the OpenWRT with IPv6 lifetime config, I guess that has as default config a lower value.
Isn’t a problem, its indicate that is a default entry.
I guess that OpenWRT send RA packets to change the prefix on devices when renew the prefix, what the MikroTik doesn’t, the packets are sent conform the lifetime, I guess.
@offtopic:
Does the Vivo offer a prefix bigger than /64?
The workaround is to use a low lifetime like 3m~10m… some day the devs will solve this.
[/quote]
When i tried this, nothing happened.
[/quote]
Hi thiagohfl,
are you still in the same issue or finding some easy & valuable solution from any expert?? i have the same issue and follow this page for the best solution, plz guide me as well
thanks in advance
[/quote]
I have no answers yet. I’m trying, if I get it to work rightly, I’ll post.
[/quote]
[/quote]
Hi thiagohfl,
