Hi, I have a native IPv6 connection which works fine. But problems start when I create firewall rules to secure inner network. It looks like IPv6 firewall is not stateful. First two rules don’t capture any packets and the last one drops everything. Am I doing wrong something?
Drop rule is for internet->intranet only, so reverse traffic must be accepted by default. There is nothing special, just basic firewall rules. I have the same for IPv4.
Icmp is vital for ipv6 fragmentation and neighbor discovery capabilities. Udp rule can be ignored. What do you mean by they are not applicable in ipv4?
Is there IPv6 traffic through the router? The accept rules for Established & Related will normally show plenty of hits if they are the top rules on a system running IPv6 traffic. I have that running on many systems although those systems are generally on ROS 5 at this point.
Yes, there is traffic. Without the drop rule I can access any ipv6 enabled webpage on my pc. But with it enabled everything timeouts and the drop rule counter is increasing. And it is the last rule in a list.
It behaves like it can’t hit connections by state. Because everything is dropped even with connection-state=new in the drop rule.
I am not sure of your interface naming, but what you should be doing is :
Permit NEW connections from internal to external (action=accept)
Then below all your earlier rules have a rule with no selection criteria and action=drop - the “drop all” rule.
You seem to be attempting to block NEW connections inbound which isn’t a good plan - better to explicitly Permit certain traffic and Deny everything else.
Inet is an internet bridge interface, Intra is a LAN bridge interface. I blocked NEW because I don’t want any new connection to access LAN from internet. In the end it doesn’t even matter if I block only NEW or all states. The problem is that firewall doesn’t hit connections with the state established or related. And these rules are at the first place. But packet counters are always zero.
I would see established and related states from new connections coming from LAN, because only new connection from internet are blocked. I’ve been using CCR with 6RCs for several months, but only now I’ve tried to enable IPv6.
