Is it possible to get IPv6 working when using Vodafone Station in Czechia? If I connect my Linux PC directly to the Vodafone Station modem/router, my IPv6 works fine. But if I connect my PC to Mikrotik CRS112-8P-4S, 7.11.2 software, no matter the settings I change on the Mikrotik, I can’t get IPv6 working on the PC.
If I try to use Automatic configuration of IPv6 on Linux, which I assume is SLAAC, I get following issue with increasing timeout in my logs, and eventually, the system resets the connection and tries again.
NetworkManager[2140]: <debug> [1696780615.7744] ndisc[0x556213091af0,"enp6s0"]: solicit: schedule sending next solicitation in 237.052
seconds
I also tried DHCPv6, and I do get an address from the Vodafone Station. But then I do not get any routing or forwarding from the Mikrotik for the IPv6.
I fiddled with the Mikrotik IPv6 settings and I tried pretty much all combinations of the options in the IPv6 Settings dialogue in WinBox.
I also tried to turn on/off Neighbor Discovery and I fiddled with its settings, no dice.
What gives? What is the secret sauce to get IPv6 working in my situation? Has anyone tried with Vodafone Station in Czechia?
