Is it possible to Connect SXTG to an EnGenius Outddor access point
Existing set up has an EnGenius ENS202EXT Antenna on top of a hill with another access point at the bottom for internet access. We have a Mikrotik SXTG Antennae and MikroTik RouterBOARD hAP ac lite and was wondering whether you would think that it would be able to access the exisiting EnGenius set up for internet access? Any help would be greatly appreciated.
Specifications for the EnGenius ENS202EXT
Wireless & Radio Specifications
Operating Frequency
2.4GHz
Operation Modes
Access Point
Repeater
Client Bridge
WDS: AP, Bridge
Frequency Radio
2.4GHz: 2400MHz ~ 2835MHz
Transmit Power
Up to 26 dBm on 2.4 GHz
Max transmit power is limited by regulatory power
Radio Chains/Spatial Streams
2x2:2
Supported Data Rates (Mbps)
2.4 GHz: Max 300
802.11b: 1, 2, 5.5, 11
802.11g: 6, 9, 12, 18, 24, 36, 48, 54
802.11n: 6.5 to 300 (MCS0 to MCS15)
Supported Radio Technology
802.11b: Direct-Sequence Spread-Spectrum (DSSS)
802.11n: Orthogonal frequency-division Multiplexing (OFDM)
Channelization
802.11n with 20/40 MHz channel width
802.11b/g with 20 MHz channel width
Supported Modulation
802.11b: BPSK, QPSK, CCK
802.11n: BPSK, QPSK, 16-QAM, 64-QAM
If they can “hear each other”.
No they can’t
EnGenius ENS202EXT
Wireless 2.4 GHz standards
RBSXTG-5HPnD-SAr2
Wireless 5 GHz standards
It is the SXTG-2hnd-2 which is 2.4Ghz. Sorry, I should have put that in earlier.
Then it should work if all the radio conditions are met. You didn’t write anything about the distance.
It is about 1.25km line of sight. Antenna is on top of a big hill
It should work.
Thanks for your help. We’ll give it a go and see if we can get them working together.
