Is it possible to edit the comment using script ?
I have Mikrotik RouterOs v5.7 with hotspot.
Is it possible to get all users with “$” in their comment and change them from user profile “0400kbps money” to user profile “0400kbps” . And then delete “$” from the comment
for example
user: AK2011
profile: 0400kbps money
comment: Allen Walker $
I want change using script to
user: AK2011
profile: 0400kbps
Yes.
Mostly anyway. You need a find that matches the comment. There are examples in the script samples on the wiki. Once you find the matching records you can set the profile and comment. Doing the string munging is a bit harder. Huh it looks like find works on strings too…
So find to locate the records with matching comments, a for loop to iterate over them, and gets to grab the field values, then some string munging, and finally sets to update them.
