Is MikroTik good for home use?
Hi all, I apologize if this is not a very appropriate question, but in the vast amount of information on the internet, I’m a little confused. Can you please tell me which router is suitable for use at home? I would appreciate your help!
What are your requirements? Are you talking about WIFi routers? Do you need more than 1 LAN cable ports too?
What is your skill level with IT in general and what experience do you have with routers thus far.
What does your budget look like?
What are your needs (ISPs one or more), throughput. Wired and WIFi ?
Many devices ??? Any special requirements
All of MikroTik’s routers are potentially useful at home. What varies is what goes on in that home, which sets the answers for which of those routers are appropriate.
If you want something little better than your ISP would provide, MikroTik gear is overkill.
If you want something with a pointy-clicky GUI that keeps you from doing stupid stuff, RouterOS is likely to frustrate you with its complexity. RouterOS has GUIs, but if the list of available MikroTik routers confuses you, WinBox, WebFig, and the mobile apps are likely to positively blow your mind.
Software that prevents you from doing stupid things tends to also prevent you from doing really clever things. This is where RouterOS comes into its own: for users who know what they’re doing and are willing to put the time into a custom configuration that does precisely what they want.
RouterOS is for those who’ve often opened up the GUI on their ISP-provided router and said, “But why can’t I just…!” RouterOS lets you identify that “just” condition and solve it.
Analogy:
Can I drive to Rome with that car ?
Yes, you can.
Can I also take the complete dining room with me ?
Errm …nope. That would require a truck.
Requirements.
What is needed ? What do you want to do ? How savvy are you ?
It depends, but Id say for 99% of all home user is ROS way to complex and will frustrate the end-user.
For the classy home-setup without VLANs, DMZ, multi-WAN, multi-SSID, a cheapo 50 to 100 Euro router with a colourful and nice GUI is much better. Most of these devices provide much more than MT, like a (little) PBX, Media-Streaming, POTN-VoiP converter, VPN and so on… but they are way more limited on the routing aspect.
On the other hand, if you are willing to learn network(ing) in-depth, go for a MT.
If you want a ROUTER, go for MT.
If you want an IAD (Integrated Access Devices) with a sexy GUI, MT is not your device.
Need Wifi, the house is not very big - 3 bedrooms. 3 gadgets (tablets and laptop). Internet is needed for everyday use, Watching movies, sometimes working from home. To be honest I’m not very good at this, thought it would be easier to choose.
@Marvinjul, you need to provide much more info:
1 … Where are you located [USA, Canada, Europe, Middle East etc.]
2 … What speed – down/Up – has your ISP providing you with and the make and model of Gateway your ISP has installed]
3 … What size is your Home and in which rooms do you want Wifi Coverage
IMO MikroTik is EXCELLENT for Home use …
Mikrotik is like a Swiss army knife, capable of doing almost anything you can think of when it comes to advanced settings but also requires some special skills to manage it.
Thus, If you’re not familiar with networking stuff in general I’d recommend you to have a look at other brands specifically made for the consumer market like asus, netgear tp-link etc.
Absolutely, if you’re good to face some pretty hard challenges when things doesn’t work as expected (for a regular SOHO user that is).
The very same can be said for any so called consumer brand device like Netgear, TP-Link, Asus, D-Link. etc. regardless of the fact that all these brands are PHD.
PHD = Push Here Dummy
What separates MikroTik from the rest of the field is its functional capability to empower it’s users when the desire [will] is there at a very affordable price. When the desire is there that POWER is addictive :slight_smile:
Well, I get your point but the user interface in these consumer market models are tailor made for that particular purpose thus you really can’t compare them to Winbox. MT doesn’t have a corresponding solution that is adapted solely to be used by the end consumer (and please don’t play the “Quick Set” card :clown_face: )
I think it’s great choice when you need more than just simple “plug it in and browse the internet” router. Things like VLANs, multiple VPNs, ability to configure everything in detail, only your imagination is the limit. Ok, it’s slightly worse, there are of course some limits, but compared to usual home routers, where there’s support for few things that people usually need, but you need to fit in standard template, it’s huge difference. You can get even more from something Linux-based with access to all internals (which RouterOS doesn’t provide), but those don’t have WinBox. And WinBox is fantastic, whoever came up with that idea should get a statue! :slight_smile:
There are some downsides, sort of. You can do more, but in order to do so, you need to know more, or be willing to learn a bit. And also be careful, because if you decide to shoot your own foot, system will be happy to help, meaning that it won’t say “no”. But there’s no need to be too scared of that, because there’s simple default config that works, so you can start with that and everything will be ok. And when you need more, you can start looking around, at your own pace. Or let someone else configure it for you, main point is that it’s possible.
because there’s simple default config that works and is good enough for 98% of the population regardless
@sob … you hit the NAIL squarely on its head :slight_smile:
Some friendly advice regarding disadvantages and to prevent a possible divorce, I do recommend buying two machines! :wink:
One with standard configuration for a rock solid internet with the sole purpose to achieve domestic peace and long term stability and the other one for playing around with when learning how to configure RouterOS. Believe me, you don’t want a nagging wife and screaming children around as soon as the internet stops working! :smiley:
Just my two cents..
Ps..
If you’re willing to learn RouterOS there are a lot of useful guides in this forum: “Useful user articles”
Just curious how you discovered MikroTik routers?
What was the reason for considering a MikroTik router?
  • A friend recommended it
  • You saw it recommended on Amazon
  • You saw it recommended on Youtube
  • You found with a Google search
While what Mozerd says “there is a default that works for 98%” may be true, I would not recommend a MikroTik, pfsense or Edgerouter (or even OpenWRT) edit: (and definitely not Cisco IOS) to someone that isn’t technically inclinded and just wants a network appliance they can plug in and answer a few simple questions.
While the MikroTik will allow that with “quickset”, once you find you want to modify something, you will be lost quickly, and as Sob said, RouterOS has no blade guards so it is easy to make mistakes that it will not prevent.
Does your ISP not provide a home router solution, or is there something missing in it that you need?
The MikroTik is very much like the picture labeled woman in this article, compared to a “consumer” based router (more like the one labeled man).
If you enjoy tweaking, you will love the MikroTik, but that doesn’t sound like the case from what you posted.
If you want to learn networking, do as Larsa recommended and get two, one to use, one to learn on (while is it using the first as its “internet” connection in a “lab”). And only play on the lab router.
:joy:LOL, Good comparison, mate :joy:
Thank you so much for your help! From your answers, I realized that it’s not that easy, but apparently it’s worth it. I will try to read the information and figure it out.
I like that a lot!
Just had MikroTik Sxt LTE6 and Hapac Lite installed to access internet via 4G.
After decades in IT support (and the usual involvement in comms troubles - even though I am not a specialist) led me to delve into the excellent docs on RouterOS and fair play to the developers and maintainers! That took some engineering! I was absolutely amazed to see the same format for modem commands I used to use to program the old routers in the 80’s!
The system worked for a few hours but is dead currently. However, that may be due to ongoing EE issues in this area (South Wales).
Modem command haven’t changed that much since '80s.
<1200 baud sound tsjirping in memory…>
Ah - I wonder if my issue is similar to some others where the solution was to update the firmware.
Resetting the modem and disabling and re-enabling the LTE1 interface always results in the same:
[admin@MikroTik] /interface lte>  info lte1 once
           pin-status: ok
  registration-status: not searching
        functionality: full
         manufacturer: "MikroTik"
                model: "R11e-LTE6"
             revision: R11e-LTE6_V025
                 imei: 356662101142260
                 imsi: 234304302700401
                 uicc: 8944303623053641326
The suppliers initially saw some errors with the SIM but am I correct in thinking that if the SIM card was dead we would not see an imei?
(Sorry if there is another forum for this type of question!)
