Is Mikrotik good option for my needs? (second, is Hex Pro vaporware?)
Greetings
what I have (built roughly around 2018)
Hex RouterBOARD 750G r3 router (original ISP was <1 Gb)
Brocade ICX 7250 ( 8 x 10Gbpe SFP+ and 48 1 Gbe ports) as primary switch . all of my key devices (3 proxmox nodes in a cluster, truenas nas , backup qnap nas, primary desktop ) are fiber connected
wifi is 3 x Unifi AC Pro, controller on LCX hosted container in Proxmox
what I would like
post-COVID and working from home, redundant ISPs
current ISP package is 1.5 Gbps I pay for which is higher than Mikrotik Hex supports
incoming (1-2 months) Fiber package offers 5G down/up and would become primary ISP
Wifi speed upgrade would be nice
Questions
  • what hardware would give be ability to take in two ISPs, one of them 5 Gb incoming from fiber gateway over Cat6 cable and connect over WAN to my primary switch (SFP+) ? I was thinking Hex Pro may be it but that seem to be vaporware with no release dates or news
  • How is Mikrotik wifi hardware for home use vs Unifi ? I think I can generally find my way around Router OS and have little Hex box running my rules, my DHCP, etc.
  • My other option is Unifi and Unifi Cloud Fiber $300 gateway that does seem to have the ports needed.
  • anything else I should consider?
Thank you!
If you have 5Gb linr then you need something that could process it so you have only these devices on the BOM list: https://mikrotik.com/products/group/ethernet-routers?f[0]=s%3Ac&f[1]={"_sfpp"%3A{"s"%3A"1","e"%3A"12"}}
however if only you want more than one 10Gb SFP port then the list shortens to: https://mikrotik.com/products/group/ethernet-routers?f[0]=s%3Ac&f[1]={"_sfpp"%3A{"s"%3A"2","e"%3A"12"}}
BTW:
5Gb to home ... what do you need it for? It's quite rethorical question but it's like ISP main line speed.
Do you have any chance to utilize it fully?
Thank you for the links, I will check them out !
as for your questions, I am interested in fiber due to much higher up/down speeds (vs cable) and need uplink speed as I use cloud backup for key information that I cannot otherwise easily replace . And cost differences between 2 Gb and 5 Gb packages are trivial...
ISP (Fiber-Optic Internet | High-Speed Fiber Internet for Your Home | Ezee Fiber) goes up to 8 Gb which are more expensive and does not present meaningful difference for me..
Not judging, just interested in as 5Gb is A LOT.
I know that 20$ less or 20$ more could be nothing for some but 8GB is much faster than 5Gb if the speed of backups is crucial but how much data do you need to backup everyday that you need so fast link.
There was a time that I did 2.5TB manually driven backups (locally) with full check bit by bit after copy + additional Veem backups going in the background at the same time and it had been lasting a few hours with 10Gb link and a Lenovo RAID storage capable of sustained 2TB write speed. Do not assume that you backup so much data every day.
Once again, not saying that the selected speed is too high or exaggerated. Just being curious.
5 GB (routing) seems to be beyond the capabilities of any low cost Mikrotik routers, the RB5009 should be the "right" device, but It falls short.
The lower cost device capable of routing around 5 GB seems to be one of the CCR2004 models, but to be on the safe side you need a CCR2116-12G-4S+.
But It seems like that ezee ISP provides their routers (eero), no idea which speed they can route, but presumably they are adeguate to the offer.
5009 has only one 10Gb port + one 2.5Gb so no way to utilize SFP+ fullu unless you combine trafic from 1Gb ports.
it implies using at leats 2 SFP+ ports so the list gets short:
https://mikrotik.com/product/ccr2004_1g_12s_2xs
https://mikrotik.com/product/ccr2116_12g_4splus
https://mikrotik.com/product/rds2216
Thank you. I was really hoping for 'Hex Pro' however I was not sure if performance targets for that device are known (i.e. unifi cloud fiber which targets similar CPU and RAM does 5 Gbps with DPI turned on)
A RB5009 should be more than adequate if used with your existing switch in a “router on a stick” configuration.
You can have your 2 WANs and any LAN VLANs trunked to the RB5009 on the SFP+
Also with 5Gbps (symmetrical internet) for a home use, it is unlikely that you’ll need any traffic shaping, so FastTrak should be on.
I can’t imagine a situation where you need to use more than 5Gbps of internet simultaneously in both directions (upload and download) for a significant duration for the RB5009 to be the bottleneck.
I use the RB5009 with a 5000/500 XGS-PON connection in a router on a stick configuration and a CRS317 managed switch. The single SFP+ port is configured as trunk and the switch splits the traffic to LAN and WAN ports, the ONT is connected to the WAN designated port on the switch.
Since the connection is Asymmetric and lower than 10G there is no practical bottleneck. In terms of performance, using fastpath the RB5009 has no issues routing the maximum connection rate, and the CPU load in in the range of 60-70%
The RB5009 is a great choice since it is compact, passively cooled (unlike the CCR2004/2116 family), and highly reliable
Thank you. I looked at RB5009 (it had generally great reviews and feedback) and was concerned about
  • the number of ports it has and port speeds (what exactly do I connect to my brocade fiber backbone, how would I accept two ISPs , one of which is incoming 5 Gb and another 1.5 Gb)
  • the age of the device as in pending replacement (which is why I asked about Hex Pro as I had great experience with Hex).
I rather not go full Unifi if I do not have to, I am just not sure that Mikrotik has any good options for me behind behind in hardware and delayed with the releases.
I also look at Omana, Route10 Alta Labs as options.
I don't think the rb5009 will be retired. Mikrotik keeps selling their devices mostly as long as possible (the dev costs have already been paid.) In many cases, even when there is a successor, the tried-and-true devices are a really good bet.
Probably you are right, and the hex pro will be the successor. When it comes out, and more importantly, when it becomes stable, is - as always - totally uncertain.
Meanwhile, the rb5009 is exceptionally stable.
The usual configuration, if you have a proper switch fabric, is to connect the single 10G port, and use it as a router-on-a-stick. The routing performance is enough to max this out with fasttrack.
The next step up is the ccr2004, which has the proper number of ports. But if you want to max everything out even without fasttrack, that's the ccr2116.
It is technically possible with the RB5009 in combination with a managed switch and a router on a stick configuration, and tunneling all vlans through the single SFP+ port. 5Gbps + 1.5Gbps traffic should be possible without a bottleneck. Note however that the configuration may be a bit complex.
There is definitely a gap in the MikroTik product line which the Hex pro is supposed to fill. At least two 10Gbps capable ports and a desktop form factor are the basics. MikroTik has stronger routers than the RB5009, however these are rack mounted, with active cooling, and are considerably more expensive than the RB5009. The Hex pro will be a very welcome addition to the product line
Thank you, I agree with the above.. I think I have heard what I needed, thank you all!
  • config with currently available (and stable!) hardware is possible but complicated (router on the stick, etc)
  • new hardware (Hex Pro) release timing is unknown. The degree to which firmware on it would be usable and stable is further unknown
  • nothing else currently in the MIkrotik product line
so for me
  • do nothing until i know for sure planned installed dates available for Fiber. 'within a month or two' could easily be longer and who knows where the hardware state is by then
  • at that point make a decision of either going rb5009 route with circa 2021 hardware or go with much faster, more recent, better ports hardware like unifi cloud fiber gateway
  • deal with consequences (rebuild config anew on Unifi including all of my DHCP setups or port to new Mikrotik device from existing Hex which should be easier)
if there is anything else I have missed, please let me know
Thank you all!
