i'm trying to use /tool fetch to measure wan latency for a script.
every successful fetch is almost exactly 1 second, regardless of the destination.
i tested:
- github
- cloudflare
- microsoft
- a local http server on my lan (<1 ms away)
the local server still reports:
duration: 1s
i also measured elapsed time around /tool fetch using :timestamp/:tonsec, and it also comes out around 1010 ms.
interestingly, routeros clearly supports sub-millisecond elapsed timing:
:put [:time command={ :delay 250ms }]
00:00:00.250734
so it doesn't appear to be a timer precision limitation.
is this expected?
if so, could /tool fetch expose actual elapsed time in milliseconds (or tcp connect / tls / ttfb timing) so it can be used for latency measurements?
sample log:
2026-08-06 11:34:35 probe cloudflare.com: DoH=1011ms HEAD=1011ms
2026-08-06 11:35:36 probe microsoft.com: DoH=1012ms HEAD=2012ms
2026-08-06 11:36:43 probe github.com: DoH=8029ms HEAD=1009ms
2026-08-06 11:37:35 probe google.com: DoH=1011ms HEAD=1010ms
2026-08-06 11:38:35 probe apple.com: DoH=1012ms HEAD=1012ms
2026-08-06 11:39:35 probe cloudflare.com: DoH=1012ms HEAD=1012ms
2026-08-06 11:40:35 probe microsoft.com: DoH=1010ms HEAD=1011ms
2026-08-06 11:41:35 probe github.com: DoH=1011ms HEAD=1011ms
2026-08-06 11:42:35 probe google.com: DoH=1012ms HEAD=1010ms
2026-08-06 11:43:35 probe apple.com: DoH=1010ms HEAD=1011ms
later in the same run:
2026-08-06 13:08:39 probe cloudflare.com: DoH=3017ms HEAD=2010ms
2026-08-06 13:09:36 probe microsoft.com: DoH=1001ms HEAD=1010ms
2026-08-06 13:10:37 probe github.com: DoH=2013ms HEAD=1010ms
2026-08-06 13:11:36 probe google.com: DoH=1010ms HEAD=1011ms
2026-08-06 13:12:36 probe apple.com: DoH=1011ms HEAD=1011ms
2026-08-06 13:13:39 probe cloudflare.com: DoH=4020ms HEAD=1012ms
