I have a gl-axt1800 router(gl-inet openwrt router with IPQ6000). Could I install RouterOS on it and how could I do it?
Thanks for any advice.
So far, “alien” hardware with ARM architecture is not really supported. There’s ARM CHR) AFAIK geared towards some particular cloud provider. And there are MT devices with ARM processors.
maybe some luck with ampera hardware … would not count on that for “home/soho” use (in that case, every routerboard turns out cheaper/more price efficient)
On gl-axt1800 ros would not happen,
OK,waiting for installation method on custom arm architecture just like installing on custom x86 hardware.
RouterOS can be installed on AMPERE™ ARM systems (bare metal), and on ARM powered cloud services via CHR image.
is there a list of AMPERE devices which are ensured/trusted to work with ROS?
