Is there any way to escape from interference
Hi friends,
Im using mikrotik 5.21v 411aH board for my wireless network, im getting frequently interference problem. is there any way to escape from that issue???please help me…
Thank you…
goog question!! why don’t you select frequencies manually, select which one got low interference.
thanks for your fast response…
I’m using manual frequencies and how many days should i have to change???
Is there any chance to escape from interference, if we place a security???
please can any one help me…
Suggest that you get a laptop that has a Wi-Fi card in it that supports 802.11a; run something like inssider from metageek and look to see what channels are in use and what channels are free or little used.
Metageek also sell USB spectrum analysers that use an SMA connector so that you can connect to your external antenna and sniff to see what other signals are present. These are very cheap and useful for troubleshooting Wi-Fi spectrum issues with non Wi-Fi signal sources.
Regards
Tom
