ISP failover + VRF with BGP
Hello! I’m trying to setting up a ISP Failover on ROS. I’ve got 2 VRFs which share all it routes with BGP.
Each VRF have this own gateway.
I’m tryng to setting up ISP failover through 2 Netwatches. When one of them detect fail, disables the gateway of there VRF and all traffic is autmatically redirected of the gateway to other VRF.
It works perfect when BPG VRF are disabled. However, when I enable both BGP VRF the scripts which have to disable the static routes not works, only one of them.
To be more exact this trouble appears when 1 of the VRF BGP rules are enabled. I don’t know why?
I give you the configuration on below:
add check-gateway=ping comment=BBB distance=1 gateway=5.5.5.1 routing-mark=VRF-CONTROL
add check-gateway=ping comment=AAA distance=1 gateway=11.11.11.1 routing-mark=VRF-CHATARRA <----------------- This is the route which is possible to disable depending if BGP VF rule is enable or not
add check-gateway=ping comment=“Netwatch ISP1” distance=1 dst-address=1.1.1.1/32 gateway=11.11.11.1%SALIDA1
add check-gateway=ping comment=“Netwatch ISP2” distance=1 dst-address=8.8.8.8/32 gateway=5.5.5.1%SALIDA0
/ip route vrf
add export-route-targets=100:1 import-route-targets=10:1 interfaces=MANAGEMENT,SALIDA0 route-distinguisher=100:1 routing-mark=VRF-CONTROL
add export-route-targets=10:1 import-route-targets=100:1 interfaces=ALQUERIA,SALIDA1 route-distinguisher=10:1 routing-mark=VRF-CHATARRA
/routing bgp instance vrf
add redistribute-connected=yes redistribute-static=yes routing-mark=VRF-CONTROL
add redistribute-connected=yes redistribute-static=yes routing-mark=VRF-CHATARRA <------------------------------------------------ This is the rule who makes my config works wrong if is enabled.
/tool netwatch
add down-script=“/ip route disable [find comment=BBB]” host=1.1.1.1 interval=10s up-script=“/ip route enable [find comment=BBB]”
add down-script=“/ip route disable [find comment=AAA]” host=8.8.8.8 interval=10s up-script=“/ip route enable [find comment=AAA]” <-------------------- This is the rule that cannot disable the static route when BGP VRF mentioned above are enabled.
Can you please share more about this setup details?
I wan to try and run it locally with couple devices.
First of all, thanks for your asnwer.
Sure, I give you all configuration. But I have tried in two Mikrotiks CCR1072-1G-8S+. Same trouble on both devices.
You can show config on below:
/interface vlan
add interface=sfp-sfpplus8 name=ALQUERIA vlan-id=10
add interface=sfp-sfpplus8 name=MANAGEMENT vlan-id=100
add interface=sfp-sfpplus2 name=SALIDA0 vlan-id=190
add interface=sfp-sfpplus2 name=SALIDA1 vlan-id=191
add address=5.5.5.4/24 interface=SALIDA0 network=5.5.5.0
add address=11.11.11.4/24 interface=SALIDA1 network=11.11.11.0
add address=10.100.64.3/22 interface=ALQUERIA network=10.100.64.0
add address=10.254.254.3/24 interface=MANAGEMENT network=10.254.254.0
set servers=8.8.8.8
add action=reject chain=forward connection-state=new in-interface=ALQUERIA out-interface=MANAGEMENT reject-with=
icmp-host-prohibited
add check-gateway=ping comment=BBB disabled=yes distance=1 gateway=5.5.5.1 routing-mark=VRF-CONTROL
add check-gateway=ping comment=AAA disabled=yes distance=1 gateway=11.11.11.1 routing-mark=VRF-CHATARRA
/ip route vrf
/lcd interface pages
set 0 interfaces=
sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Madrid
/tool netwatch
