Hi everyone,
I’m not a complete noob with rOS, but haven’t encountered this type of connection before. Just changed the ISP, and they gave me some parameters to connect my Mikrotik hap ac2 to the internet. I know I probably should start from a fresh setup, but I have many things setup and I probably wouldn’t know how to set them up again without hours and hours of researching again.
I was given:
Connection IP: XX.XX.129.YYY
SUBNET MASK 255.255.224.0
WAN GATEWAY XX.XX.128.1
VLAN ID 735
(leaving parts of the connection IP and wan gateway, might be relevant. XX parts in connection IP and wan gateway are the same, probably should be).
From what I’ve seen online, I need to create a new address list, entered XX.XX.129.YYY/19 (is this right?), interface is ether1 (this is the port I connected to their media converter), network was automatically populated with XX.XX.128.0. When I click ok, a new route was automatically created in the route list with dst. Address XX.XX.128.0/19, gateway is ether1. I can’t seem to find where O need to input the VLAN ID, or If I have entered the given parameters correctly.
Can I get any help?
