ISP with DHCP
Hello!
I want toconnect my LAN to internet throw Mikrotik.
I must connect to my ISP not with a static IP but like a DHCP client.
Please how can I do it.
Under IP address table what IP I must put to public interface.
How about IP Routes Table?
Please can someone send me the wright steps or where can I find an example for doing this.
Thank You in advance.
Hai fren,
i think is not hard, just setup dhcp-client on your pubilc interface, and put dns by peer and add default gateway or set dns by manually, than put masquerade rule on local interface.
with Mikrotik's will help you to making route to the world. :wink:
regards
Hasbullah.com
OK I’ll try it.
Thank you.
Hello.
But What gateway I must add an my IP route table?
Thanks.
tell the dhcp-client to use default gateway and it will be automatic.
