Good morning,
I have bought my hapAC2 and upgraded to latest 6.43.7. I already run RB3011UiAS in my office, so I’m familiar with router config. On My hapAC2 I have strange issues.
Device connected directly with cable to router can be pinged from router only if I delete ARP record for that device. Even after that, ping is working only 2-3 times. See attached pictures:
Here is my configuration. Any ideas?
Thank You.
Description to my config
My simple setup:
ether1-wan - ISP modem
ether2-trunk - Dlink switch in trunk mode
ether3-5 - LAN devices
# dec/09/2018 09:20:23 by RouterOS 6.43.7
# software id = FM9E-58T1
# model = RBD52G-5HacD2HnD
# serial number = 9EF709C73784
add admin-mac=B8:69:F4:5D:2D:21 auto-mac=no name=bridge-home protocol-mode=none
set [ find default-name=ether1 ] mac-address=64:70:02:F9:24:24 name=ether1-wan
set [ find default-name=ether2 ] name=ether2-trunk
/interface vlan
add interface=ether2-trunk name=vlan1-mngmt vlan-id=1
add interface=ether2-trunk name=vlan2-home vlan-id=2
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys name=home supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed name=guest supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto \
mode=ap-bridge security-profile=home ssid=HomeWifi vlan-id=2 wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=\
auto mode=ap-bridge security-profile=home ssid=HomeWifi vlan-id=2 wireless-protocol=802.11 wps-mode=disabled
add keepalive-frames=disabled mac-address=BA:69:F4:5D:2D:25 master-interface=wlan1 multicast-buffering=disabled name=\
guest_2g security-profile=guest ssid=Guest wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/ip hotspot profile
add name=pool-home ranges=192.168.2.50-192.168.2.200
add name=pool-guest ranges=192.168.9.5-192.168.9.100
add add-arp=yes address-pool=pool-home always-broadcast=yes disabled=no interface=bridge-home name=dhcp-home
add address-pool=pool-guest always-broadcast=yes disabled=no interface=guest_2g name=dhcp-guest
add bridge=bridge-home interface=ether3
add bridge=bridge-home interface=ether4
add bridge=bridge-home interface=ether5
add bridge=bridge-home interface=wlan1
add bridge=bridge-home interface=wlan2
add bridge=bridge-home interface=vlan2-home
/interface bridge vlan
add bridge=bridge-home tagged=ether2-trunk untagged=ether3,ether4,ether5,wlan1,wlan2 vlan-ids=2
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=bridge-home list=LAN
add comment=defconf interface=ether1-wan list=WAN
add address=192.168.2.1/24 interface=bridge-home network=192.168.2.0
add address=192.168.1.1/24 interface=vlan1-mngmt network=192.168.1.0
add address=192.168.9.1/24 interface=guest_2g network=192.168.9.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1-wan
/ip dhcp-server lease
add address=192.168.2.7 client-id=1:0:1e:a0:0:65:42 comment=stb mac-address=00:1E:A0:00:65:42 server=dhcp-home
add address=192.168.2.12 client-id=1:0:5:cd:72:d5:64 mac-address=00:05:CD:72:D5:64 server=dhcp-home
add address=192.168.2.0/24 comment=network-home dns-server=192.168.2.5 domain=.lan gateway=192.168.2.1 netmask=24 \
next-server=192.168.2.5 ntp-server=192.168.2.5
add address=192.168.9.0/24 comment=network-guest dns-server=1.1.1.1,8.8.8.8 domain=.guest gateway=192.168.9.1
set allow-remote-requests=yes servers=192.168.2.5
/ip dns static
add address=192.168.2.1 name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid log-prefix="drop_invalid: "
add action=accept chain=input dst-port=53 protocol=udp
add action=accept chain=input dst-port=8291 protocol=tcp
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN log=yes log-prefix=\
"drop_input: "
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface-list=WAN log=yes log-prefix="drop_fwd: "
add action=dst-nat chain=dstnat dst-port=22005 protocol=tcp to-addresses=192.168.2.5 to-ports=22
add action=dst-nat chain=dstnat dst-port=18005 protocol=tcp to-addresses=192.168.2.5 to-ports=80
add action=dst-nat chain=dstnat dst-port=22007 protocol=tcp to-addresses=192.168.2.7 to-ports=22
add distance=1 dst-address=10.1.1.0/24 gateway=192.168.2.5
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Bratislava
/system identity
set name=gw.lan
/tool graphing interface
add allow-address=192.168.0.0/16
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
