Issue with DHCP on VLAN 1 on a switch configured as a router
Good morning. I’m facing a problem I can't seem to solve: I can't get my DHCP service (range 172.16.0.1/16) to pass through my bridge and VLAN 1; nothing is able to obtain an address from that DHCP pool.
I also tried injecting DHCP traffic from another device via ports 7 and 8 with VLAN 1 tagged.
Can anyone help me figure out what I’m doing wrong?
[aminaktor@MK-RB_Router-Salon] > export
# 2026-06-29 18:45:08 by RouterOS 7.23
# software id = WJCB-GVIP
# model = CRS310-8G+2S+
# serial number = HFH09FR0JTS
add fast-forward=no ingress-filtering=no name=SW_Main vlan-filtering=yes
/interface vlan
add interface=SW_Main name=SW_HDoIP vlan-id=23
add interface=SW_Main name=SW_LAN0 vlan-id=20
add interface=SW_Main name=SW_LAN1 vlan-id=21
add interface=SW_Main name=SW_LAN2 vlan-id=22
add interface=SW_Main name=SW_WAN1 vlan-id=11
/caps-man configuration
add channel.band=2ghz-b/g/n country=spain datapath.bridge=SW_Main .vlan-id=21 \
    .vlan-mode=use-tag installation=indoor mode=ap name=WIFI_EFF5 \
    security.authentication-types=wpa-psk,wpa2-psk ssid=WIFI_EFF5
add country=spain datapath.bridge=SW_Main .vlan-id=22 .vlan-mode=use-tag \
    hide-ssid=yes installation=indoor mode=ap name=WIFI_EFF5_Domo00 \
    security.authentication-types=wpa-psk,wpa2-psk ssid=WIFI_EFF5_Domo00
add country=spain datapath.bridge=SW_Main .interface-list=all .vlan-id=22 \
    .vlan-mode=use-tag hide-ssid=yes installation=indoor mode=ap name=\
    WIFI_EFF5_Domo02 security.authentication-types=wpa-psk,wpa2-psk ssid=\
    WIFI_EFF5_Domo02
/interface wifi datapath
add disabled=no name=datapath_LAN1 vlan-id=21
add disabled=no name=datapath_LAN2 vlan-id=22
add disabled=no name=datapath_LAN0 vlan-id=20
add disabled=no name=datapath_WAN1 vlan-id=11
/interface wifi security
add disabled=no ft=yes ft-over-ds=yes name=WIFI_EFF5
add disabled=no ft=no ft-over-ds=no name=WIFI_EFF5_Domo
/interface wifi configuration
add datapath=datapath_LAN1 disabled=no mode=ap name=cfg1 security=WIFI_EFF5 \
    ssid=WIFI_EFF5
add datapath=datapath_LAN2 disabled=no mode=ap name=cfg2 security=\
    WIFI_EFF5_Domo ssid=WIFI_EFF5_Domo00
add datapath=datapath_LAN2 disabled=no mode=ap name=cfg3 security=\
    WIFI_EFF5_Domo ssid=WIFI_EFF5_Domo02
add name=dhcp_pool0 ranges=172.21.250.1-172.21.255.254
add name=dhcp_pool1 ranges=172.22.250.1-172.22.255.254
add name=dhcp_pool2 ranges=172.16.250.1-172.16.255.254
add name=dhcp_pool3 ranges=172.16.0.2-172.16.255.254
add address-pool=dhcp_pool0 interface=SW_LAN1 name=dhcp1
add address-pool=dhcp_pool1 interface=SW_LAN2 name=dhcp2
add address-pool=dhcp_pool3 interface=SW_Main name=dhcp3
/queue simple
add max-limit=200M/200M name=queue1 target=172.21.255.191/32,172.21.255.188/32
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=SW_LAN0
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=WIFI_EFF5 name-format=\
    identity slave-configurations=WIFI_EFF5_Domo00,WIFI_EFF5_Domo02
add bridge=SW_Main frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether1 pvid=11
    interface=ether3 pvid=23
    interface=ether5 pvid=11
    interface=ether6 pvid=11
add bridge=SW_Main frame-types=admit-only-vlan-tagged interface=ether7
add bridge=SW_Main frame-types=admit-only-vlan-tagged interface=ether8
add bridge=SW_Main frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
/interface bridge vlan
add bridge=SW_Main tagged=SW_Main,sfp-sfpplus1,ether7,ether8 untagged=\
    ether1,ether6,ether5 vlan-ids=11
add bridge=SW_Main tagged=SW_Main,sfp-sfpplus1,ether7,ether8 vlan-ids=20
add bridge=SW_Main tagged=SW_Main,sfp-sfpplus1,ether7,ether8 vlan-ids=21
add bridge=SW_Main mvrp-forbidden=ether1 tagged=\
    SW_Main,sfp-sfpplus1,ether7,ether8 vlan-ids=22
add bridge=SW_Main tagged=SW_Main,sfp-sfpplus1,ether7,ether8 untagged=ether3 \
    vlan-ids=23
add bridge=SW_Main tagged=ether7,ether8,sfp-sfpplus1 untagged=SW_Main \
    vlan-ids=1
/interface wifi capsman
set enabled=yes interfaces=SW_LAN0 package-path="" require-peer-certificate=no \
    upgrade-policy=none
add address=172.20.0.1/16 interface=SW_LAN0 network=172.20.0.0
add address=172.21.0.1/16 interface=SW_LAN1 network=172.21.0.0
add address=172.22.0.1/16 interface=SW_LAN2 network=172.22.0.0
add address=172.16.0.1/16 interface=SW_Main network=172.16.0.0
/ip dhcp-client
add interface=SW_WAN1 name=SW_WAN1 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=172.22.255.210 mac-address=14:08:08:69:93:FA server=dhcp2
add address=172.21.255.191 client-id=1:94:de:80:66:c2:90 mac-address=\
    94:DE:80:66:C2:90 server=dhcp1
add address=172.21.255.188 client-id=1:0:8:22:4c:72:fc mac-address=\
    00:08:22:4C:72:FC server=dhcp1
add address=172.21.255.133 client-id=1:dc:a6:32:3b:4f:f8 mac-address=\
    DC:A6:32:3B:4F:F8 server=dhcp1
add address=172.16.0.0/16 dns-none=yes gateway=172.16.0.1
add address=172.21.0.0/16 gateway=172.21.0.1
add address=172.22.0.0/16 gateway=172.22.0.1
set servers=1.1.1.1,8.8.4.4 verify-doh-cert=yes
/ip firewall address-list
add address=127.0.0.1 list=VPN_22_ALLOWED
add address=88.22.44.189 list=VPN_22_ALLOWED
add action=drop chain=forward disabled=yes dst-port=80 in-interface=SW_WAN1 \
    protocol=tcp src-address-list=!VPN_22_ALLOWED
add action=accept chain=forward connection-state=established,related disabled=\
    yes in-interface=SW_WAN1
add action=dst-nat chain=dstnat disabled=yes dst-port=80 protocol=tcp \
    to-addresses=172.22.1.1 to-ports=8123
add action=masquerade chain=srcnat comment=WAN1 out-interface=SW_WAN1
/ip service
set ftp address=172.22.0.0/16
set ssh address=172.22.0.0/16
set telnet address=172.22.0.0/16
set www address=172.22.0.0/16
set winbox address=172.22.0.0/16
set api address=172.22.0.0/16
set api-ssl address=172.22.0.0/16
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=MK-RB_Router-Salon
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
add address=time.cloudflare.com
/system routerboard settings
# Firmware upgraded successfully, please reboot for changes to take effect!
set auto-upgrade=yes
/system swos
set address-acquisition-mode=static identity=SW_Salon static-ip-address=\
    172.16.0.12
Maybe I missed something, but nowhere do I see a DHCP server configured on the bridge/vlan1 . . . Or, for that matter, an untagged port with PVID 1 that could access it.
To use VLAN 1 is always a bad idea, let alone tagged, due to differences in its implementation on different devices. Better to use some VLAN ID other than 1 or 0 also in an all-VLAN setup
Use it heavily, and always have. It's the default for untagged . . . Likely more standard than other solutions - anything else would be an exception. (Cisco, Netgear, TPLink, Mikrotik all coexist flawlessly).
Then again, I have zero desire (or reason) to use 100% tagged . . . . (and I'd never try to use VLAN1 tagged)
I'll argue that any VLAN1 ussues would be from trying to run it tagged (which, by definition, it is not) or incompetence in config.
Heck, if you run a router/switch with no tagging, untagged traffic is still considered VLAN1 . . .
What is acting as the dhcp server? Is it using untagged traffic? How is it connected to the CRS310-8G+2S+ ?
Are you planning to use SwOS? Noticed this:
/system swos
    172.16.0.12
It isn't usual to see someone using tags with vlan 1. It is allowed by the IEEE802.1Q standard, but some vendors (e.g. Ubiquiti with Unifi) won't even allow you to configure vlan 1 with tags, and they use "vlan 1" almost interchangably with "untagged", although they allow other vlans to be either tagged or untagged. But when Unifi documentation mentions vlan 1, it means "untagged".
Best practice is to not tag vlan 1 if interoperability is a goal.
And don't forget Rules #1 and #2 :wink::
Well, it’s clear I messed up the VLAN1 configuration. Let me explain: aside from this device, I didn't have anything on VLAN1. However, when I tried connecting a couple of salvaged UniFi AC-Mesh units (which do work), I realized that without VLAN1, they couldn't be configured via the CloudKey—and that’s where I hit a wall during the setup process.
If I understand correctly, should VLAN1 always remain untagged on the bridge? Does this setting belong in the "bridge > VLAN" table or in the bridge configuration itself?
Also, this device was originally just a standard switch. However, since my RB750Gr2 (which was acting as the router) suddenly died, I was forced to turn this unit into a router—which is why there are leftover SwOS configuration traces. I’ve ordered a new RB750Gr3 to replace the broken one, but I’d still like to know exactly what I did wrong so I can configure it correctly once the new unit arrives.
I’d appreciate any help.
I never set anything implicitly for VLAN1 on my bridge. With ports set to PVID 1, RouterOS creates the entry automagically. You won't see an entry in interfaces/VLAN either (nor should you).
This seems to be a "trap" that I am seeing new ROs users face plant on frequently . . . Just because you don't see something, don't feel obligated to add something. Most of this type of stuff is covered by default, and adding extraneous parameters just breaks things and makes troubleshooting harder.
Which segment is the CloudKey connected to? The CloudKey doesn't care what vlan it it on, it just expects it to be untagged. Ubiquiti Unifi specifies vlan1 whenever they mean "untagged". I use a raspberry pi as a unifi controller, and it is not on vlan1, it is just on a hybrid link with the "management" connection using the untagged vlan specified by pvid. The access points think this is vlan1 but all it sees is untagged "standard ethernet" traffic for its management, and uses other tagged vlans for the SSIDs.
If you use the mikrotik CLI commands
/interface/bridge print
/interface/bridge/port print
/interface/bridge/vlan print
you will be able to see where the pvid is set to 1. Also, where dynamic settings are applied.
For the SW_Main (bridge) that should show pvid 1 (which is the default).
If you add a port to the bridge and don't specify a pvid, it will use pvid 1. You can also explicitly specify pvid=1 but I am not sure if it will show up in an export or not, since that is the default value. And if you then plug a pc into that bridge port, it should get an ip address from dhcp_pool3.
Does that work?
Have you made any progress?
It doesn't appear that ether4 is used the the config you posted.
If you add
    interface=ether4
With no other changes, it should add ether4 as a bridge-port with vlan 1 untagged.
If you then plug a PC with dhcp client into ether4, does it get an ip address (like 172.16.255.254) ?
You have told the dhcp server for 172.16.0.0/16 not to provide any dns server info. Was that intentional? Without dns, many things won't work.
