Hi there,
We have been having an issue with propagating our routes between our Core Datacenter Routers.
Pretty sure this is a simple misconfiguration issue but we have been looking at it for the last few weeks.
We have VRRP’s in place for failover and I believe this issue is that the next hop address is not showing up as the VRF
our BGP setup on both CCR’s looks like the following:
10.10.10.1 is an address on the physical interface, 10.10.10.255 is a loopback address (
remote.address=10.10.10.254/32 .port=179
local.address=10.10.10.255 .role=ibgp
connect=yes listen=yes routing-table=main router-id=10.10.10.255 templates=default as=136595
nexthop-choice=default address-families=ip,l2vpn,l2vpn-cisco,vpnv4 cisco-vpls-nlri-len-fmt=auto-bits
output.redistribute=connected,static,bgp,vpn .network=bgp-networks
bgp VPN:
Flags: X - disabled, I - inactive
0 name="bgp-mpls-vpn-1"
import.router-id=XXX-VRF .route-targets=136595:4
export.route-targets=136595:4 .redistribute=connected,static,vpn
route-distinguisher="136595:4" vrf=XXX-VRF label-allocation-policy=per-vrf
I have obfuscated the following addresses:
$NEXT.EBGP is our next hop - its a ip address of our connecting ISP
$L2TP.IP is the public l2tp address of the related remote WAN site address of this client
routing table of second router: (L2tp connection of $XXX.burwood on other router)
Flags: D - dynamic; X - disabled, I - inactive, A - active;
c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vp>
H - hw-offloaded; + - ecmp
5 As dst-address=0.0.0.0/0 routing-table=XXX-VRF gateway=10.51.252.250@XXX-VRF
immediate-gw=10.51.252.250%VLAN1737.XXXdistance=1 scope=30 target-scope=10
vrf-interface=VLAN1737.XXXsuppress-hw-offload=no
D y dst-address=0.0.0.0/0 routing-table=XXX-VRF gateway=10.51.252.250@XXX-VRF
immediate-gw=10.51.252.250%VLAN1737.XXXdistance=200 scope=20 target-scope=10
6 As dst-address=10.10.10.254/32 routing-table=XXX-VRF gateway=VLAN1737.XXX@XXX-VRF
immediate-gw=VLAN1737.XXXdistance=1 scope=30 target-scope=10 suppress-hw-offload=no
D y dst-address=10.10.10.254/32 routing-table=XXX-VRF gateway=XXX-VRF@XXX-VRF immediate-gw=XXX-VRF
7 IsH dst-address=10.51.11.0/24 routing-table=XXX-VRF gateway=XXX.burwood@XXX-VRF immediate-gw=""
DAyH dst-address=10.51.11.0/24 routing-table=XXX-VRF gateway=10.10.10.254 distance=200 scope=20
target-scope=30
DAc dst-address=10.51.252.0/24 routing-table=XXX-VRF gateway=VLAN1737.XXX@XXX-VRF
immediate-gw=VLAN1737.XXXdistance=0 scope=10 target-scope=5
local-address=10.51.252.248%VLAN1737.XXX@XXX-VRF
D y dst-address=10.51.252.0/24 routing-table=XXX-VRF gateway=XXX-VRF@XXX-VRF immediate-gw=XXX-VRF
DAyH dst-address=10.51.252.253/32 routing-table=XXX-VRF gateway=10.10.10.254 distance=200 scope=20
target-scope=30
DAyH dst-address=$L2TP.IP/32 routing-table=XXX-VRF gateway=10.10.10.254 distance=200 scope=20
target-scope=30
Routing table of first router: (L2TP connection of $XXX.burwood on this router)
c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn;
0 As dst-address=0.0.0.0/0 routing-table=XXX-VRF gateway=10.51.252.250@XXX-VRF immediate-gw=10.51.252.250%VLAN1737.XXX
distance=1 scope=30 target-scope=10 vrf-interface=VLAN1737.XXXsuppress-hw-offload=no
D yH dst-address=0.0.0.0/0 routing-table=XXX-VRF gateway=10.10.10.255 distance=200 scope=20 target-scope=30
DAyH dst-address=10.10.10.254/32 routing-table=XXX-VRF gateway=10.10.10.255 distance=200 scope=20 target-scope=30
1 As dst-address=10.51.11.0/24 routing-table=XXX-VRF gateway=XXX.burwood@XXX-VRF immediate-gw=XXX.burwood distance=1
DAc dst-address=10.51.252.0/24 routing-table=XXX-VRF gateway=VLAN1737.XXX@XXX-VRF immediate-gw=VLAN1737.XXXdistance=0
scope=10 target-scope=5 local-address=10.51.252.249%VLAN1737.XXX@XXX-VRF
D yH dst-address=10.51.252.0/24 routing-table=XXX-VRF gateway=10.10.10.255 distance=200 scope=20 target-scope=30
DAc dst-address=10.51.252.253/32 routing-table=XXX-VRF gateway=XXX.VRRP@XXX-VRF immediate-gw=XXX.VRRP distance=0
scope=10 target-scope=5 local-address=10.51.252.253%XXX.VRRP@XXX-VRF
DAc dst-address=$L2TP.IP/32 routing-table=XXX-VRF gateway=XXX.burwood@XXX-VRF immediate-gw=XXX.burwood distance=0
scope=10 target-scope=5 local-address=$NEXT.EBGP%XXX.burwood@XXX-VRF
Currently dropping the VRRP interface from the first router so that it connects on the second router caused the connection to VRRP to failover correctly. However traffic cannot route to the first router’s L2tp interface so the sites connection is dropped. I believe this is due to the next hop on the VRF routing table not being resolvable for the $L2TP.IP connection between the routers over BGP.
Let me know if I can provide any more context around this, really appreciate any help towards this as its been abit of an uphill battle.
Cheers.
Gabe
