issues with a 5GHz antenna
I need a little help
i have a tower with a RB435, one of the interfaces is running an R52Hn card.
 name="AP5" mtu=1500 mac-address=00:0C:42:66:94:31 arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="000C42669431" mode=ap-bridge ssid="Sea11" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5805 band=5ghz-onlyn channel-width=20mhz scan-list=default wireless-protocol=unspecified
      rate-set=default supported-rates-b="" supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=""
      basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps max-station-count=2007 distance=dynamic tx-power=23 tx-power-mode=card-rates noise-floor-threshold=default
      nv2-noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled wds-default-bridge=none wds-default-cost=100
      wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
      preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any ht-extension-channel=disabled
      ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
      ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192
      ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7 frame-lifetime=0
      adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
It is running with this Antenna
when i scan from it i pick up a couple SSIDs, the lowest i pick up at -50
now when i try to connect a RB711, Particularly this one, i pick up SSIDs and again some at good signals but i just can’t pickup the antenna i have set up, even physically putting the SSID into the interface will not make it connect.
could someone enlighten me as to what i have done wrong
You currently have your wireless profile unspecified. Set it to 802.11 or if you are using other profiles set it accordingly.
as far as i understand if i run in “unspecified” it was suppose to default to 802.11, however i will give that a go
We have run into this problem before and this is what fixed it for us. Did it work for you?
i need the grab a unit at some point and take it home, i can see said tower from my house so i can try test the changes then
