Issues with VPN over IPV6 (IPv6 DS Lite)
Hi everyone,
Most recently, I have changed the provider and started using Dual-Stack Lite (DS-Lite).
The traffic is being routed without local NAT over the ipipv6-tunnel interface to the provider network.
Everything works fine except the SurfShark VPN. I can see a dynamically created NAT rule for the 172.130.8.0/24
subnet and have internet access from the private wifi WIFI network. Accessing to most sites is very slow (Google services, Youtube, and Gmail) or does not work at all.
I’m out of ideas and if someone could help that would be great.
# jul/13/2022 21:43:19 by RouterOS 7.4rc2
# software id = G22P-GRK6
# model = RBD53iG-5HacD2HnD
add name=private
add admin-mac=2C:C8:1B:BD:2B:63 auto-mac=no name=public
add name=ssvpn_blackhole protocol-mode=none
set [ find default-name=ether1 ] name=ether1_wan
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=bangladesh disabled=no distance=indoors frequency=2447 \
    installation=indoor mode=ap-bridge ssid=publicwifi wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce \
    country=germany disabled=no distance=indoors frequency=5260 installation=\
    indoor mode=ap-bridge nv2-security=enabled ssid=privatewifi wireless-protocol=\
    802.11
/interface ipipv6
add dscp=0 !keepalive local-address=:: name=ipipv6-tunnel remote-address=\
    2a02:3040:0:200::b
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip ipsec mode-config
add connection-mark=under_ssvpn name="SS VPN mode config" responder=no
/ip ipsec policy group
add name=ssvpn
/ip ipsec profile
set [ find default=yes ] dh-group=ecp256,ecp521,modp2048,modp1024 \
    enc-algorithm=aes-256,aes-192,3des proposal-check=strict
add dh-group=modp4096,modp2048,modp1024 dpd-interval=disable-dpd \
    enc-algorithm=aes-256 hash-algorithm=sha256 name="SS VPN profile"
/ip ipsec peer
add address=de-ber.prod.surfshark.com exchange-mode=ike2 name="SS VPN server" \
    profile="SS VPN profile"
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512,sha256,sha1,md5 \
    enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,3des pfs-group=none
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc,aes-192-cbc name=\
    proposal-H
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=0s name=\
    "SS VPN proposal" pfs-group=none
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=public-ip-pool ranges=192.168.0.10-192.168.0.40
add name=private-ip-pool ranges=172.30.8.5-172.30.8.55
add address-pool=public-ip-pool interface=public name=defconf
add address-pool=private-ip-pool interface=private name=dhcp-server-private
/routing table
add fib name=ssvpn_blackhole
add bridge=public comment=defconf interface=ether2
add bridge=public comment=defconf interface=ether3
add bridge=private comment=defconf interface=ether4
add bridge=public comment=defconf interface=ether5
add bridge=public comment=defconf interface=wlan1
add bridge=private comment=defconf interface=wlan2
/ipv6 settings
set accept-router-advertisements=yes
add interface=public list=LAN
add interface=ether1_wan list=WAN
add interface=private list=LAN
add address=192.168.0.1/24 comment=defconf interface=public network=\
    192.168.0.0
add address=192.0.0.2/29 interface=ipipv6-tunnel network=192.0.0.0
add address=172.30.8.1/24 interface=private network=172.30.8.0
add address=172.30.8.0/24 dns-server=1.1.1.1 gateway=172.30.8.1
add address=192.168.0.0/24 dns-server=1.1.1.1 gateway=\
    192.168.0.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
/ip firewall address-list
add address=172.30.8.0/24 list=under_ssvpn
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=accept chain=forward connection-mark=under_ssvpn
    connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=under_ssvpn \
    passthrough=yes src-address-list=under_ssvpn
add action=mark-routing chain=prerouting new-routing-mark=ssvpn_blackhole \
add action=change-mss chain=forward connection-mark=under_ssvpn new-mss=1360 \
    passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=!0-1375
/ip ipsec identity
add auth-method=eap certificate="SS VPN CA" eap-methods=eap-mschapv2 \
    generate-policy=port-strict mode-config="SS VPN mode config" peer=\
    "SS VPN server" policy-template-group=ssvpn username=xxx
/ip ipsec policy
add dst-address=0.0.0.0/0 group=ssvpn proposal="SS VPN proposal" src-address=\
    0.0.0.0/0 template=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.0.0.1 pref-src=\
    "" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add gateway=ssvpn_blackhole routing-table=*401
add gateway=ssvpn_blackhole routing-table=ssvpn_blackhole
/ipv6 dhcp-client
add add-default-route=yes interface=ether1_wan pool-name=ipv6-pool \
    rapid-commit=no request=address
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
Please note that the ipipv6-tunnel interface got 10.6.0.233/32 from the VPN and maybe it can be related to the issue.
[admin@MikroTik] > ip/route/print
Flags: D - DYNAMIC; A - ACTIVE; c, s, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#     DST-ADDRESS     GATEWAY          DISTANCE
0  As 0.0.0.0/0       192.0.0.1               1
  DAc 10.6.0.233/32   ipipv6-tunnel           0
  DAc 172.30.8.0/24   private                 0
  DAc 192.0.0.0/29    ipipv6-tunnel           0
  DAc 192.168.0.0/24  public                  0
1  As 0.0.0.0/0       ssvpn_blackhole         1
[admin@MikroTik] > ip/address/print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS         NETWORK      INTERFACE
;;; defconf
0   192.168.0.1/24  192.168.0.0  public
1   192.0.0.2/29    192.0.0.0    ipipv6-tunnel
2   172.30.8.1/24   172.30.8.0   private
3 D 10.6.0.233/32   10.6.0.233   ipipv6-tunnel
[admin@MikroTik] > ipv6/route/print
Flags: D - DYNAMIC; I, A - ACTIVE; c, d, y - COPY; H - HW-OFFLOADED
DIdH ::/0                       ::%ether1_wan           1
DAc  2a02:3102:4c00:6c::/64     ether1_wan              0
DAc  fe80::%ether1_wan/64       ether1_wan              0
DAc  fe80::%public/64           public                  0
DAc  fe80::%private/64          private                 0
DAc  fe80::%ssvpn_blackhole/64  ssvpn_blackhole         0
[admin@MikroTik] > ipv6/address/print
Flags: D - DYNAMIC; G, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
#    ADDRESS                                   INTERFACE        ADVERTISE
0 DL fe80::2ec8:1bff:febd:2b63/64              public           no
1 DL fe80::f4a6:b9ff:fe19:4b29/64              ssvpn_blackhole  no
2 DL fe80::2ec8:1bff:febd:2b65/64              private          no
3 DL fe80::2ec8:1bff:febd:2b62/64              ether1_wan       no
4 DG 2a02:3102:4c00:6c:2176:6163:4a5b:89c3/64  ether1_wan       no
[admin@MikroTik] > ip/ipsec/policy/print
Flags: T - TEMPLATE; D, A - ACTIVE; * - DEFAULT
Columns: PEER, TUNNEL, SRC-ADDRESS, DST-ADDRESS, PROTOCOL, ACTION, LEVEL, PH2-COUNT
#     PEER           TUNNEL  SRC-ADDRESS    DST-ADDRESS  PROTOCOL  ACTION   LEVEL   PH2-COUNT
0 T *                        ::/0           ::/0         all
1 T                          0.0.0.0/0      0.0.0.0/0    all
2  D  SS VPN server  yes     10.6.0.233/32  0.0.0.0/0    all       encrypt  unique          1
[admin@MikroTik] > ip/ipsec/active-peers/print
Columns: ID, STATE, UPTIME, PH2-TOTAL, REMOTE-ADDRESS
# ID                         STATE        UPTIME  PH2-TOTAL  REMOTE-ADDRESS
0 de-ber.prod.surfshark.com  established  15m49s          1  217.138.216.245
This is because fasttracking is incompatible with IPsec. So add connection-mark=no-mark to the action=fasttrack-connection rule and it should become better.
This suggests an issue with Path MTU discovery. /ip ipsec policy add src-address=172.30.8.0/24 dst-address=172.30.8.0/24 action=none place-before=[find where group=ssvpn proposal=“SS VPN proposal” template] should fix this.
If you want to understand the background, both issues have been discussed multiple times here on the forum, it should not be complicated to find those topics.
