L009UiGS-2HaxD and Zyxel PMG3000-D20B
I have a L009UiGS-2HaxD and a Zyxel PMG3000-D20B ONT.
Previously, I had an external GPON module and the Mikrotik was connected via Ethernet with it to the Internet.
Now, I have a Zyxel PMG3000-D20B ONT SFP module and the Mikrotik uses it to connect directly to the internet.
IPv4 and IPv6 were working before, but with the SFP module, I don’t get a v6 address anymore. IPv4 is still working.
Any thoughts, what could be wrong?
[admin@MikroTik] > /export hide-sensitive
# 2024-12-16 18:32:07 by RouterOS 7.16.1
# software id = NPTX-3ZRK
# model = L009UiGS-2HaxD
# serial number = <redacted>
add admin-mac=xxxx auto-mac=no comment=defconf name=bridge
add disabled=yes name=bridge_guest
add name=bridge_internet
add name=bridge_iot
add name=bridge_old
set [ find default-name=sfp1 ] loop-protect=off sfp-rate-select=low
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=sfp1 name=vlan50_sfp vlan-id=50
add interface=ether7 name=vlan87_up vlan-id=87
add interface=ether3 name=vlan91 vlan-id=91
add interface=ether7 name=vlan91_up vlan-id=91
/interface ethernet switch port-isolation
set 7 forwarding-override=switch1-cpu
set 6 mirror-ingress-target=switch1-cpu
set 6 forwarding-override=""
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.30-192.168.88.254
add name=iot-pool ranges=192.168.91.10-192.168.91.100
add name=old-pool ranges=192.168.87.20-192.168.87.100
add address-pool=default-dhcp interface=bridge lease-time=1w10m name=defconf
add address-pool=iot-pool interface=bridge_iot lease-time=1w30m name=iot
add address-pool=old-pool interface=bridge_old lease-time=2w23h30m name=old
/queue simple
add max-limit=60M/22M name=wan target=vlan50_sfp,vlan50_sfp
/queue type
add kind=sfq name=default-sfq
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=hitzing4
add bridge=bridge_iot interface=ether8 pvid=91
add bridge=bridge_iot interface=vlan91
add bridge=bridge_iot interface=iot
add bridge=bridge_iot interface=vlan91_up
add bridge=bridge_old interface=vlan87_up
add bridge=bridge interface=ether1
add bridge=bridge_internet ingress-filtering=no interface=vlan50_sfp pvid=50
set udp-timeout=10s
/ip settings
set tcp-syncookies=yes
/ipv6 settings
set accept-router-advertisements=yes
/interface bridge vlan
add bridge=bridge_iot disabled=yes tagged=ether3 vlan-ids=91
add bridge=bridge disabled=yes untagged=ether3 vlan-ids=1
add bridge=bridge_iot disabled=yes tagged=ether3 vlan-ids=1
add bridge=bridge_internet vlan-ids=50
set 0 mirror-egress-target=switch1-cpu
add interface=vlan50_sfp list=WAN
add interface=bridge_internet list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.91.1/24 interface=bridge_iot network=192.168.91.0
add address=192.168.99.1/24 interface=bridge_guest network=192.168.99.0
add address=192.168.89.1/24 interface=wireguard1 network=192.168.89.0
add address=192.168.87.1/24 interface=bridge_old network=192.168.87.0
add address=10.10.1.2/24 interface=sfp1 network=10.10.1.0
/ip dhcp-client
add disabled=yes interface=bridge
add disabled=yes interface=vlan50_sfp
/ipv6 dhcp-client
add add-default-route=yes interface=bridge_internet pool-name=delegation pool-prefix-length=56 request=address,prefix use-interface-duid=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=log chain=output log=yes
add action=log chain=input log=yes
add action=accept chain=input dst-port=13231 protocol=udp
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward out-interface-list=WAN
add action=drop chain=forward out-interface-list=LAN
/ipv6 firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu out-interface=bridge_internet passthrough=yes protocol=tcp tcp-flags=syn
add action=change-mss chain=output new-mss=clamp-to-pmtu out-interface=bridge_internet passthrough=yes protocol=tcp tcp-flags=syn
add action=change-mss chain=forward disabled=yes new-mss=clamp-to-pmtu passthrough=yes protocol=tcp tcp-flags=syn
/ipv6 nd
set [ find default=yes ] dns=2a02:ca00:dc:102::51,2a02:ca00:dc:101::51,2606:4700:4700::1111,2606:4700:4700::1001 hop-limit=64 interface=\
    bridge ra-interval=20s-1m
/system logging
add topics=wireless
add topics=wireguard
add disabled=yes prefix=dhcp topics=debug
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system routerboard settings
set enter-setup-on=delete-key
The problem seems to sit in the SFP module. I ordered a different SFP module from fs.com which now works with ipv6
Hallo derOberfranke,
i have actually the same problem ! Ont top i have the problem that the connection to Telekom dropped off approximately 20 times per day. I have also ordered a GPON ONU Modul from fs.com ! Is you problem solved with this GPON Modul ?
mfg Jonny
@Jonny I never had connection problems other than IPv6 not working. But I am using a different ISP and not Telekom. Anyway, the fs.com module works perfectly with IPv6.
Now i have received the Stick from FS but he not have a HEX Modem ID between 12-16 characters. They have just a serialnumber with 11 characters. This can not be registered on the Telekom !!!
So it seems to be a problem on telecom's side.
Check the documentation from fs.com. you may need to SSH into the sfp module to get/set the id. Don't mix up serial number with the id that you need for telekom
So all is fine !!! The GPON Serialnumber (12 HEX digits) can only see with the SSH !
This GPON Serialnumber get to Telekom and they actualize this in his system. Then it works without issues.
Thank you all for help !
Hi, sorry to be late here, but can you share what exact module you bought from fs.com in combination with fiber from Deutsche Telekom?
Thanks :slight_smile:
Did a little digging.
Zyxel PMG3000-D20B no ipv6, Firmware bug…
You can try and go through the trouble of re-flashing it or just get a new one.
