L009uigs leds control
Hey,
I’m playing with l009 and figured out that only few leds can be controlled. I can enable/disable/modify only ether1 leds. All other ports can’t be controlled and don’t turn off even with all-leds-off=immediate.
Is it a bug or it’s a hardware limitation?
That feature doesn’t work with L009 and some other Mikrotik devices.
I have an L009, RB5009 and Chateau AX. The ability to turn off all the LED’s works on the 5009 and Chateau.
