Are you sure your PPPoE setup is re-establishing correctly? I ran a test w/6.40rc24 with just L2TP server and client machines. They re-established fine whenever I killed a link in the middle between the server and client.
PPPoE should have a timeout value set very much like L2TP and the messages you are highlighting with the value 0.0.0.0/0 are irrelevant. You can see from the complete log below that the 0.0.0.0/0 destination is not important at least in the scope o the error. I’d have to dive into it more to see if there is a logical reason for the 0.0.0.0/0 value or if the error is just poorly formatted. Either way that alone does not indicate the problem.
TLDR; verify that your PPPoE client is re-establishing correctly. You may need to define a timeout value in either or both of the PPPoE client or server. This may require a call to your ISP or whoever runs the PPPoE server.
[admin@l2tp-client1] >
03:54:19 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 192.168.1.6:1701
03:54:19 echo: l2tp,debug,packet tunnel-id=3, session-id=0, ns=9, nr=7
03:54:19 echo: l2tp,debug,packet (M) Message-Type=HELLO
03:54:27 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 192.168.1.6:1701
03:54:27 echo: l2tp,debug,packet tunnel-id=3, session-id=0, ns=9, nr=7
03:54:27 echo: l2tp,debug,packet (M) Message-Type=HELLO
(33 messages discarded)
03:54:35 echo: l2tp,debug tunnel 5 entering state: wait-ctl-reply
03:54:35 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:35 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:35 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:35 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:35 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:35 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:35 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:35 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:54:35 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:54:35 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:35 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:36 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:36 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:36 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:36 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:36 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:36 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:36 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:36 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:54:36 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:54:36 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:36 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:37 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:37 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:37 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:37 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:37 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:37 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:37 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:37 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:54:37 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:54:37 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:37 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:39 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:39 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:39 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:39 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:39 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:39 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:39 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:39 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:54:39 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:54:39 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:39 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:43 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:43 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:43 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:43 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:43 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:43 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:43 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:43 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:54:43 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:54:43 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:43 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:51 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:51 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:51 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:51 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:51 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:51 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:51 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:51 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:54:51 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:54:51 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:51 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:59 echo: l2tp,debug tunnel 5 received no replies, disconnecting
03:54:59 echo: l2tp,debug tunnel 5 entering state: dead
03:54:59 echo: l2tp,debug session 1 entering state: dead
03:54:59 echo: l2tp,ppp,info l2tp-client1: terminating… - session closed
03:54:59 echo: l2tp,ppp,debug l2tp-client1: LCP lowerdown
03:54:59 echo: l2tp,ppp,debug l2tp-client1: LCP down event in starting state
03:54:59 echo: l2tp,ppp,info l2tp-client1: disconnected
(2 messages discarded)
03:55:00 echo: l2tp,debug tunnel 6 entering state: wait-ctl-reply
03:55:00 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:55:00 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:55:00 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:55:00 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:55:00 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:55:00 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:55:00 echo: l2tp,debug,packet Firmware-Revision=0x1
03:55:00 echo: l2tp,debug,packet (M) Host-Name=“l2tp-client1”
03:55:00 echo: l2tp,debug,packet Vendor-Name=“MikroTik”
03:55:00 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=6
03:55:00 echo: l2tp,debug,packet (M) Receive-Window-Size=4
(99 messages discarded)
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: sent IPCP ConfReq id=0x8
03:55:01 echo: l2tp,ppp,debug,packet <addr 172.16.1.61>
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd MPLSCP ConfAck id=0x4
03:55:01 echo: l2tp,ppp,debug l2tp-client1: MPLSCP opened
03:55:01 echo: l2tp,ppp,info l2tp-client1: connected
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd CCP ConfAck id=0x4
03:55:01 echo: l2tp,ppp,debug,packet <mppe 1000040>
03:55:01 echo: l2tp,ppp,debug l2tp-client1: CCP opened
03:55:01 echo: l2tp,ppp,info l2tp-client1: using encoding - MPPE128 stateless
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd IPCP ConfAck id=0x8
03:55:01 echo: l2tp,ppp,debug l2tp-client1: IPCP opened
03:56:01 echo: l2tp,debug,packet (M) Message-Type=HELLO
03:56:01 echo: l2tp,debug,packet rcvd control message from 192.168.1.2:1701 to 192.168.1.6:1701
03:56:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=2, nr=4
03:56:01 echo: l2tp,debug,packet sent control message (ack) to 192.168.1.2:1701 from 192.168.1.6:1701
03:56:01 echo: l2tp,debug,packet tunnel-id=4, session-id=0, ns=5, nr=3
03:56:01 echo: l2tp,debug,packet rcvd control message (ack) from 192.168.1.2:1701 to 192.168.1.6:1701
03:56:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=3, nr=5
03:56:01 echo: l2tp,ppp,debug,packet l2tp-client1: sent LCP EchoReq id=0x0
03:56:01 echo: l2tp,ppp,debug,packet <magic 0x7de9507a>
03:56:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd LCP EchoRep id=0x0
03:56:01 echo: l2tp,ppp,debug,packet <magic 0x66331cb9>
03:56:31 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd LCP EchoReq id=0x0
03:56:31 echo: l2tp,ppp,debug,packet <magic 0x66331cb9>
03:56:31 echo: l2tp,ppp,debug,packet l2tp-client1: sent LCP EchoRep id=0x0
03:56:31 echo: l2tp,ppp,debug,packet <magic 0x7de9507a>
03:57:01 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=4, session-id=0, ns=5, nr=3
03:57:01 echo: l2tp,debug,packet (M) Message-Type=HELLO
03:57:01 echo: l2tp,debug,packet rcvd control message from 192.168.1.2:1701 to 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=3, nr=5
03:57:01 echo: l2tp,debug,packet sent control message (ack) to 192.168.1.2:1701 from 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=4, session-id=0, ns=6, nr=4
03:57:01 echo: l2tp,debug,packet rcvd control message (ack) from 192.168.1.2:1701 to 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=4, nr=6
