I have an problem with a l2tp ipsec site to site connection that i am unable to solve.
Location 1 i have a rb1100
Location 2 i have 750g r3
I want a piont to point l2tp ipsec, a very easy setup but i am running into some problems.
Every time i want to connect i am not getting a fase 2
At location 1 i have setup l2tp for a couple of devices and it workt fine.
So lets try a l2tp with a ipsec preshared secet, the same setup as location 1. but i am getting the same error,
parsing packet failed possible cause wrong password.
i really know that the password is correct!
Oke lets go back, lets test somting easy. I will just try a pptp connection with the same password and username. and yea that works.
I really dont know what to do? i thing that when i solve that problem with that password, i can go test the piont to piont tunnel
this is the config from location 2:
