I’ve a lab setup, where several RouterBoards should connect to a central VPN server (also Routerboard). I successfully configured a L2TP server and the client RouterBoards establish the L2TP tunnel (“Use IPSec” is checked). According to the IPSec SA table the L2TP sessions are encrypted, but not using PFS though it is configured in the default proposal on the VPN server.
Is this the expected behavior? The L2TP server respects all IPSec settings in the default-proposal but not PFS.
Any chance to get the ability to see the PFS status in future ROS versions?
I’m okay with your answer but I know for sure some people (customers for example) want to see if PFS is “really” working.
