Hi there,
I am very new to Microtik, and I am trying to set up remote access to my network.
My router is behind Verizon router, hence not many Firewall rules.
I’ve spent a few days trying to solve the issue, but I seem to be missing something.
Here’s my config
# 2024-11-25 16:17:50 by RouterOS 7.15.2
# software id = HFQU-A853
# model = CRS520-4XS-16XQ
add arp=proxy-arp name=bridge-lan-10
add name=bridge1
set [ find default-name=qsfp28-1-1 ] fec-mode=fec91
set [ find default-name=qsfp28-3-1 ] fec-mode=fec91
/interface l2tp-server
add name=l2tp-in1 user=*****
add name=LAN
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add name=pool-lan-10 ranges=10.10.10.5-10.10.10.254
add name=pool-vpn ranges=10.1.1.2-10.1.1.50
add address-pool=dhcp_pool0 interface=bridge1 name=dhcp1
add address-pool=pool-lan-10 bootp-support=none interface=bridge-lan-10 name=dhcp-lan-10
/port
set 0 name=serial0
/ppp profile
set *0 local-address=10.1.1.1 remote-address=pool-vpn
add bridge=bridge-lan-10 interface=qsfp28-1-1
add bridge=bridge-lan-10 interface=qsfp28-1-2
add bridge=bridge-lan-10 interface=qsfp28-1-3
add bridge=bridge-lan-10 interface=qsfp28-1-4
add bridge=bridge-lan-10 interface=qsfp28-2-1
add bridge=bridge-lan-10 interface=qsfp28-2-2
add bridge=bridge-lan-10 interface=qsfp28-2-3
add bridge=bridge-lan-10 interface=qsfp28-2-4
add bridge=bridge-lan-10 interface=qsfp28-3-1
add bridge=bridge-lan-10 interface=qsfp28-3-2
add bridge=bridge-lan-10 interface=qsfp28-3-3
add bridge=bridge-lan-10 interface=qsfp28-3-4
add bridge=bridge-lan-10 interface=qsfp28-4-1
add bridge=bridge-lan-10 interface=qsfp28-4-2
add bridge=bridge-lan-10 interface=qsfp28-4-3
add bridge=bridge-lan-10 interface=qsfp28-4-4
set lldp-med-net-policy-vlan=1
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=bridge-lan-10 list=LAN
add interface=l2tp-in1 list=LAN
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=10.10.10.1 interface=bridge-lan-10 network=10.10.10.1
/ip dhcp-client
add interface=sfp28-1
add address=10.10.10.0/24 gateway=10.10.10.1
add address=192.168.88.0/24 gateway=192.168.88.1
add chain=input port=1701,500,4500 protocol=udp
add chain=input protocol=ipsec-esp
add action=masquerade chain=srcnat out-interface=sfp28-1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=*******
/system clock
set time-zone-name=America/New_York
Thanks in advance!
