L2TP/IPSec with DLNA? - with CAPsMAN and VLANs
I have a hexS and a wAPac and trying to implement the below topology
  • internet from provider via PPPoE
  • hexS with CAPsMAN for wAP ac (a single one for now, planned to add more to cover the house)
  • two VLANs: one for LAN devices and another one for SmartHome devices
  • L2TP IPSec VPN to access home network (LAN) from remote
    Almost everything works as expected, the only thing that does not work is UPNP/DLNA?: if I log into VPN I can’t see my media server advertised although the same server is reachable - e.g. via SMB: I can browse and download/upload…
Did I miss something? Should this setup - e.g. DLNA for VPN clients - work?
Many thanks, Janos
# model = RB760iGS
#  Basic Interfaces
/interface bridge add name=bridge-default admin-mac=**:**:**:**:**:** auto-mac=no fast-forward=no protocol-mode=none vlan-filtering=yes
/interface pppoe-client
add name=pppoe-out1 interface=ether1 add-default-route=yes allow=mschap1,mschap2 dial-on-demand=yes disabled=no keepalive-timeout=disabled \
    user=**** password=****
/interface vlan
add name=vlan-default   vlan-id=10 interface=bridge-default arp=proxy-arp
add name=vlan-SmartHome vlan-id=20 interface=bridge-default
add interface=ether2 pvid=20 bridge=bridge-default frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes
add interface=ether3 pvid=10 bridge=bridge-default frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes
add interface=ether4 pvid=10 bridge=bridge-default frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes
add interface=ether5 bridge=bridge-default
add interface=sfp1   bridge=bridge-default
/interface bridge vlan
add vlan-ids=10 bridge=bridge-default tagged=bridge-default,ether5 untagged=ether3,ether4
add vlan-ids=20 bridge=bridge-default tagged=bridge-default,ether5 untagged=ether2
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=IOT
add interface=ether1         list=WAN
add interface=vlan-default   list=LAN
add interface=ether3         list=LAN
add interface=ether4         list=LAN
add interface=vlan-SmartHome list=IOT
add interface=ether2         list=IOT
# Basic IP
/ip dhcp-client
add interface=ether1 disabled=no
add interface=vlan-default   address=192.168.1.1/24 network=192.168.1.0
add interface=vlan-SmartHome address=192.168.2.1/24 network=192.168.2.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=30m
add name=dhcp-pool-default   ranges=192.168.1.101-192.168.1.199
add name=dhcp-pool-SmartHome ranges=192.168.2.101-192.168.2.199
add name=dhcp-server-default    address-pool=dhcp-pool-default   disabled=no interface=vlan-default
add name=dhcp-server-SmartHome  address-pool=dhcp-pool-SmartHome disabled=no interface=vlan-SmartHome
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 domain=lan gateway=192.168.1.1 netmask=24 caps-manager=192.168.1.1 wins-server=192.168.1.1
add address=192.168.2.0/24 dns-server=8.8.8.8,8.8.4.4 domain=iot gateway=192.168.2.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1  name=router.lan
add address=192.168.1.98 name=MikroTik-wAPac
/ip smb
set domain=WORKGROUP enabled=yes interfaces=vlan-default
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=vlan-default type=internal
/ip hotspot profile
# IP Firewall
add chain=input   action=accept connection-state=established,related,untracked      comment="defconf: accept established,related,untracked"
add chain=input   action=accept protocol=udp dst-port=500,4500,1701                 comment="L2TP IPSec VPN - UDP 500,4500,1701"
add chain=input   action=accept protocol=ipsec-esp                                  comment="L2TP IPSec VPN - ESP"
add chain=input   action=drop   connection-state=invalid                            comment="defconf: drop invalid"
add chain=input   action=accept protocol=icmp                                       comment="defconf: accept ICMP"
add chain=input   action=accept dst-address=127.0.0.1                               comment="defconf: accept to local loopback (for CAPsMAN)"
add chain=input   action=drop   in-interface-list=!LAN                              comment="defconf: drop all not coming from LAN"
add chain=forward action=accept ipsec-policy=in,ipsec                               comment="defconf: accept in ipsec policy"
add chain=forward action=accept ipsec-policy=out,ipsec                              comment="defconf: accept out ipsec policy"
add chain=forward action=fasttrack-connection connection-mark=!ipsec connection-state=established,related comment="defconf: fasttrack"
add chain=forward action=accept connection-state=established,related,untracked      comment="defconf: accept established,related, untracked"
add chain=forward action=accept in-interface-list=LAN out-interface-list=IOT        comment="allow from LAN to IOT"
add chain=forward action=reject in-interface-list=IOT out-interface-list=LAN reject-with=icmp-network-unreachable comment="reject from IOT to LAN"
add chain=forward action=drop   connection-state=invalid                            comment="defconf: drop invalid"
add chain=forward action=drop   connection-nat-state=!dstnat connection-state=new in-interface-list=WAN comment="drop all from WAN not DSTNATed"
/ip firewall mangle
add chain=forward action=mark-connection ipsec-policy=in,ipsec  new-connection-mark=ipsec passthrough=yes \
    comment="mark ipsec connections to exclude them from fasttrack - in"
add chain=forward action=mark-connection ipsec-policy=out,ipsec new-connection-mark=ipsec passthrough=yes \
    comment="mark ipsec connections to exclude them from fasttrack - out"
add chain=srcnat action=masquerade ipsec-policy=out,none out-interface-list=WAN comment="defconf: masquerade"
#  CAPsMAN
/caps-man channel
add name=channel-2ghz band=2ghz-g/n    extension-channel=XX   control-channel-width=20mhz
add name=channel-5ghz band=5ghz-a/n/ac extension-channel=XXXX skip-dfs-channels=no
/caps-man datapath
add name=datapath-default   bridge=bridge-default client-to-client-forwarding=yes local-forwarding=no vlan-id=10 vlan-mode=use-tag
add name=datapath-SmartHome bridge=bridge-default client-to-client-forwarding=yes local-forwarding=no vlan-id=20 vlan-mode=use-tag
/caps-man rates
add name=rate-5ghz basic=24Mbps,36Mbps,48Mbps,54Mbps supported=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs=mcs0-7 \
    vht-supported-mcs=mcs0-9
add name=rate-2ghz basic=6Mbps,54Mbps supported=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs=mcs0-7 \
/caps-man security
add name=security-5ghz authentication-types=wpa2-psk passphrase=**** disable-pmkid=yes encryption=aes-ccm group-key-update=5m \
    group-encryption=aes-ccm
add name=security-2ghz authentication-types=wpa2-psk passphrase=**** disable-pmkid=yes encryption=aes-ccm group-key-update=5m
/caps-man configuration
add name=apCfg-5ghz ssid=myLAN       channel=channel-5ghz datapath=datapath-default   rates=rate-5ghz security=security-5ghz \
    distance=indoors hw-retries=7 installation=indoor mode=ap country=**** rx-chains=0,1,2,3 tx-chains=0,1,2,3 guard-interval=any
add name=apCfg-2ghz ssid=mySmartHome channel=channel-2ghz datapath=datapath-SmartHome rates=rate-2ghz security=security-2ghz \
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge-default
add disabled=no interface=ether5
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac,an master-configuration=apCfg-5ghz name-format=identity
add action=create-dynamic-enabled hw-supported-modes=b,gn  master-configuration=apCfg-2ghz name-format=identity
# Generic
/system clock
set time-zone-name=Europe/****
/tool mac-server
/tool mac-server mac-winbox
# L2TP IPsec
/interface l2tp-server
add name=l2tp-in1 user=testuser
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128 hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512,sha256,sha1 enc-algorithms="aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-cbc,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm"
/ip ipsec mode-config
add address-pool=dhcp-pool-default name=l2tp-mode split-include=0.0.0.0/0
/ppp profile
add name=l2tp-ipsec-profile dns-server=192.168.1.1 interface-list=LAN local-address=192.168.1.1 remote-address=dhcp-pool-default \
    use-encryption=yes use-upnp=yes wins-server=192.168.1.1
set *FFFFFFFE bridge=bridge-default dns-server=192.168.1.1
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=l2tp-ipsec-profile enabled=yes ipsec-secret=**** use-ipsec=yes
/ppp secret
add name=testuser password=**** profile=l2tp-ipsec-profile
# vlan-default is already in upnp interfaces, just add the l2tp one
/ip upnp interfaces
add interface=l2tp-in type=internal
Which DLNA server do you use? There’re some details on what might be the issue in the links below but its due to the multicasting not going through the tunnel.
http://forum.mikrotik.com/t/working-dlna-routing-example-basic/120281/1
http://forum.mikrotik.com/t/multicast-over-vpn-for-site-to-site/95236/1
