When enable L2TP/IPSec, ros will be generate a peer, then I have add follow firewall rule, but cannot connect VPN.
Please advise which rule is missing ?
[admin@MikroTik] /ip firewall> filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward
What is your WAN interface / IP? Please do not type out the full public IP. use: x.x.x.(last octet)
What do the logs show?
The logs are going to be the best bet to find the problem. I don’t see anything “wrong” off-hand. Most likely you have a different setting somewhere between the client and the router.
With that said, I would configure your L2TP accept chain as an inbound on a specific interface - your WAN. I also like to see the ports separated into their own accept statements.
