I have a problem with L2TP / IPSEC in a client, several users connect from the same connection behind a NAT and with L2TP it is impossible, when a user connects, he disconnects the one that is already connected.
I’ve been reading why this happens and change the L2TP from port strict to port override but still failing
How can I do it? for now I solved the issue by putting one user with PPTP and another with L2TP, but ideally, all users use L2tp
this is the current configuration in the mikrotik
I too get this however it is not so much a problem as expected behaviour. You can use split VPN types as you have found or you could set up a VPN from the router and some sort of policy based routing to get around this.
Hello
It is not possible to put a VPN in the router of the office where the connected laptops are, besides that the users sometimes move from site and need to have the connection in the equipment
So far we have implemented PPTP without problems, but everyone does not recommend using it and L2TP + IPSEC is a much more reliable option.
I’ve been reading days on this issue and it seems to be a problem of RouterOS and different connections from the same IP with NAT, in “theory” it was resolved with the 6.38 and port override, but I still fail, if there is an L2TP connection and another is made from the same IP, the first connection is disconnected and the second connection remains active. It is temporarily solved with PPTP and L2TP, but I would prefer to solve it
regards
