Layer 7 protocol
Hi to all,
I would to drop Windows Live Messenger connections. In which way Can I use layer 7 protocol?
Where I get the correct regular expression of messenger protocol?
And for others protocols?
http://wiki.mikrotik.com/wiki/L7
the list of regular expressions,
http://l7-filter.sourceforge.net/protocols
Thanks a lot.
I’m blocking messenger connection but I would to block also video or audio streaming. I used regexp of RTSP, FLASH, RtP but the traffic isn’t blocked.
Can you help me?
the L7 filter doesn’t work perfectly with so many traffics, in the sites suggested above you will find a list of protocol that tested works perfect, but i prefer dont use L7 it’s “EAT” a lot of cpu, i allways try to block some traffics with “triks” maybe, some ports, some ips, some content with “content” match..
Content? Can I have more informations about content matching please?
