Layer 7 protocols not working
Hello
i was using layer 7 based traffic prioritization on ros v 5.22 and was working fine
but in ROS v6 rc6 it’s not working
i used the guide at
http://wiki.mikrotik.com/wiki/Basic_traffic_shaping_based_on_layer-7_protocols
You have to specify used pattern at least, however note that most of l7 protocol does not provide 100% effect for marking traffic.
the pattern is already specified in the example
and also it was working in v 5.22
Example has too much layer7 patterns. Please be more specific about pattern that does not work.
none of the pattern are working as of now
that is why i told “Layer 7 protocols filter not working”
I've used default patter for HTTP,
/ip firewall layer7-protocol> print detail
0 ;;; http
name="http" regexp="http/(0.9|1.0|1.1) [1-5][0-9][0-9] [\x09-\x0d -
~](connection:|content-type:|content-length:|date:)|post [\x09-\x0d -
http/[01].[019]"
/ip firewall filter> print
1 chain=forward action=log layer7-protocol=http log-prefix=""
[admin@MikroTik] /ip firewall filter> print d
/ip firewall filter> print stats
CHAIN ACTION BYTES PACKETS
1 forward log 44 920 191
/system package print detail
5 name="system" version="6.0rc7" build-time=jan/09/2013 14:32:00
scheduled=""
ok i deleted all entry and created again
and surprisingly it worked
Thank you all
revival of a dead thread.
I have blocked FB via a drop rule in the forward chain as FB does not play as well as I had hoped with layer 7 packet matching and blocks other sites required for business here.
I have added an exception for my machine at the top of the chain.
      chain=forward action=accept protocol=tcp src-address=192.168.20.196 src-port=80,443,53 log=no log-prefix=""
the above does not function or allow my traffic through.
however, if I modify this to not have the src-port set, the rule matches and works as expected.
    chain=forward action=accept protocol=tcp src-address=192.168.20.196 log=no log-prefix=""
Now the fun part.
I have a layer 7 rule to match ‘twitter’
the regular expression for matching states:
^.+(twitter.com).*$
and it is enabled in the forward chain
39    ;;; BLOCK TWITTER
      chain=forward action=reject reject-with=icmp-host-prohibited layer7-protocol=Twitter log=no log-prefix=""
it is matched and blocks traffic even despite the exception for my specific ip address above.
What am I missing within the configuration here in order to allow exceptions to work for both direct forward chain rules as well as layer 7 rules?
Thank-You,
