LCD only showing sfp1-gateway
I am using the RB2011UAS-2HND-IN and would like to change the port showing in the LCD-menu from the “sfp1-gateway” to “ether1-gateway”
When I enter the CLI, all I can do is the following
/lcd> edit
backlight-timeout  enabled  value-name
wheras the documentation says it should have the following options
enabled
backlight-timeout
read-only-mode
current-interface
time-interval
all-interface-mode
I am running RouterOS v5.24.
Thanks in advance.
Use the touchscreen to change between the interfaces.
I am not currently at my device, but when I tried pushing it, the only thing that happened was that it changed between kbs and pps. nothing else.
Does it have multiple touch areas or only one?
I don’t remember but you need to either swipe left and right or up and down. You may also need to recalibrate your LCD if you have not already done so.
ohh, that’s more than I knew, thanks a lot, will test it as soon as I get home.
Thanks a bunch : )
